9006 to 9005 low beam conversion
Disclaimer: by using these guides, you are removing me from any liability that is related to any injury that might occur. I would suggest having a friend help you on these installs, if you are unsure about your abilities for any of these projects, get a professional to do it.
Credit goes to www.bmwe34.net for the original write up and pictures
9005 to 9005 low beam conversion
Estimated time: ~30 min
Tools:
Dremel / cutting tool
Knife or blade
With this conversion you should be able to increase your output from your stock halogens by a lot. Take a look at the 9005 bulb as opposed to the 9006. Notice how the 9005 has the tip covered in that grey stuff, essentially cutting down on light output.
Instructions:
1. Take your 9006 bulbs and compare them with the 9005. Notice how the top notch on the 9006 is a bit smaller than the 9005, also note that the 9005 has two "prong" thingies inside. Take your dremel or cutting utility and cut a bit off the top notch, maybe a cm or so. Then file down the two prongs inside. Put the bulbs back in, replacing the 9005's with the 9006's and you're done.
Note: when I did this with my stock halogens I notice a significant difference in brightness, when I did it with some aftermarket superwhites, I couldn't really tell. Others on this board have, so just take that into consideration.
Tools:
Knife or blade
Instructions:
blacktsxwagon
Oct 27, 2015 10:12 PM
9005, 9006, acura, beam, beams, bulb, comparison, conversion, convert, difference, diy, low, making, rsx, yukon
