Worn Rotors
Worn Rotors
I have a 98 cl. I just replaced the front rotors and pads. Now the rear brakes are squealing but when i brake they stop then when i release they start again. Can anyone tell me of an easy way to tell if the rear rotors are too thin and need replacing? theres a way to gauge them but i dont know how. Also can i just replace the pads and be okay?
just replace the pads.. and as long as the rotor surface isnt bumpy and cut up all over the place.. it should be fine
The rear brakes are always the first ones to go. The front brakes are only applied under heaving braking. The rears are used for everything. Odds are, you might just need to replace em. Take your tire off, and take a look at it.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
