wiring help for hid on fogs (w/pics)
SANJOCL
okay so it looks like a lot of people are using the OEM switch harness for their fog lights. but i wanted to be able to have my own switch which is kinda smaller and wouldnt require me to order the factory fog switch. i have a ton of rocker switches laying around so i figure id use one for my fogs...ANYWAY...
little bit of a wiring question. i mean it looks like everything is pretty straight forward EXCEPT for one small wiring question.
okay so i kinda laid out the wiring harness and loosely put everything in its place. fogs lights obviously plug into the ballast, relay harness into the ballast, very bottom wire to the positive of the batt, and the one right above would be to the neg. the wire at the top middle is the other side of the fog set.
since im not using the fog harness where do i plug the blue and white socket right above the relay harness wire plugs into the ballast. and where would i splice in the switch that would control everything.
apologies if this explanation has been covered long before and is now burried in our archive of threads lol...and i hope my question wasnt too confusing.
