Window will not go up or down....??
1999CL2.3.........closed door..........heard an "odd sound".........window will not go up or down. I've "manually" pulled it up so that it is shut, but it still have free travel.
If I use the switch on the door, I can hear the motor running inside the door and there is a little "grinding" at the end of each up or down stroke.
Please tell me I just knocked the window off of the lift bar?? ?? ??
How easy will it be for me to get inside my door without completely screwing up the factory seal of the door? Any special tools or replacement clips needed to return the door to original state?
Not as good of a repairman as most of you guys, so be kind!
thanks!
thanks!
fear and Loathing
Its easy just make sure you take off the molding around the handle and lock. and there will be a little clip/plug for the electric just dont rip it off you should be straight. few screws. just push up and off
Roll Tide!
http://home.comcast.net/~bobobutler/...ra_Window.html
it's definitely your regulator I just had that same problem about 3 weeks ago and found this site when I searched. Made it alot easier than I expected. Hope this helps!
FINALLY ordered a new one and fixed it Saturday...........
5 minutes to get the door panel off...
10 minutes to remover old dead motor...
5 minutes to install new motor...
3 FRIGGIN HOURS TO REPLACE DOOR PANEL!! !! !! !! !! !! !! !! !! !! !! !! !!
...is now Carbon Fiber'd
haha yeah putting the door panel back on was a bitchz
The Hefty 2.2
Originally Posted by Racer510dude
LOL...yes it can be a bitch if you do not know the trick.
TRICK ! ? ! ?
NOW YOU GUYS TELL ME THERE'S A TRICK!! !! !!
i actually just ran into the same problem..... and for me the problem was the wire part of it ripped and it clogged the passage way. what i did was order the reuglator and motor which comes as a whole for 75 bucks and changed it. if you dont know how to change it like i did it might take a while till you figure it out...... took me about an hour and a half.
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
