Whats Wrong With My Car..
NAWWWWSSSSSS
1 Post
I'm looking for you car know it alls to bless me with your smarts.. i was driving down the high'way and when i was getting off i pushed in my clutch and it was dead (barely recoiled) i struggled to drive it home which was only a few blocks because i could barely shift into the gears but i got it into my garage.. and foudn a place that would take a look at it i decided i was goin to try to drive it to the shop but the clutch had no effect at this time.. when the car was off it would slide right into a gear but when i started the car it would jump like the clutch wasnt even in.. but rolled over anyway.. if that makes sense.. can sumone tell me whats wrong with my ride.. it has the orignal clutch and i just rolled over 90,000 miles.. and how much am i looking on spending to fix this problem..
LA`s Top CL
try checking if ur clutch is stuck by kicking it from under the clutch if so thats the master slender or something thats what is kinda wrong with my car when i first got it back from my swap
hopefully it's just the slave cylinder, I had that happen to my last car(turbo dsm) and it was the slave cylinder, it looks really easy to replace on these cars, its located just to the left of the exhaust manifold it's a little black cylinder with a rod sticking out of it. See if it's leaking clutch fluid and check your clutch fluid resevoir
acuratl26
04-23-2020 07:30 PM
Hines57
09-24-2015 01:58 PM
