what stuff do i need
07 tl-s in
i need to cut a hole in my fender what should i use?it has to be perfect/exact measurments and smooth...also what can i use besides two sided tape to hold my doorsills on(opoxy/glue).my door on the passenger side closed and kinked it.(hammered on a board as best as possible any other tricks?if not it doesn't look that bad).i want it to be as flush and as stuck down as possible.
07 tl-s in
before i leave work.trying to get this done today, but i don't wanna rush and want the right tools cuz if i mess up i'm gonna have a big hole in my fender,so what makes the best/cleanest/easiest cuts?(i only did this once,and i didn't need to be exact)
07 tl-s in
dremel ok,i need kind of a weird/rectangular shape.so i'm gonna make the basic hole, then have to file it right? they want $105 for install of a $25 dollar part. i'll diy i'm just about makin hole's in the ride other than that i'm good,this hole to be right on the money or i'm fucked......
Nom Nom Nom Nom
Be sure to (the blue masking tape.)tape off the area that you are cutting.. It will keep the burrs down and give you a little protection if you do skip off and knick your paint. Plus the tape gives you a grove to cut to help steady it. You would want to use a cutting wheel tool for the dremel. Just take your time.
rcs86
08-02-2016 06:52 PM
kb1rl
09-30-2015 10:17 AM
