Weird idle problem
Weird idle problem
I haven't driven the CL in about 3 weeks. Started it up today and was greeted with the idle bouncing around like mad. After about a minute and a half, it settles down but runs really rough. Anybody have any ideas, or should I run to my mechanic after Frances blows through. Or should I just park it under a tree ($0 comp deduct.)?
Right click - Save as
Idle at startup
Idle after a couple of minutes
What exhaust sounds like during above clip
Idle at startup
that is the iac. idle air control valve. it sits under the throttle body. and has a coolant hose going to it. it also makes ur tranny feel like it is shifting rough. easy to change only 2 bolts. (i think). try taking it off and cleaning it out. with some carb cleaner.
SidhuSaaB
05-30-2020 12:40 AM
rboller
09-23-2015 02:49 PM
