? on waterpump and t-belts.
it's a 99 3.0 and im planning on replacing all the belts and waterpump soon. does anyone know if i can use parts from a 98-02 honda accord 3.0 v6?. all i know is that they are the same type motor so... yea?. any help would be great thanks!!!
yes they are the same. its not that hard just take your time and good luck with the tensioner.. i would invest in the proper tool from honda for it. i think its only like 15$ then you could re-sell it here for the same price, cause im sure alot of people are gonna do their own tbelts. good luck pimpin.. oh yea use a breakerbar and prop it up in the a arm then disconnect the middle wire on the distributor cap, tap the starter.. your crank bolt will be loose (it turns in the correct direction for that). and you wont have a headache or a busted knuckle. good luck..
