Want to change oil today but don't know capacity?
Old 08-01-2012 | 09:16 AM
panzer948's Avatar
Hi, previous owner has promised me the manual for my 1999 2.3 but still hasn't come thru. Got some friends coming over in a bit to help with some maintenance items and I thought I would change the oil while they were here. Problem is, I have no idea how much to add (quart wise). Think I will put Vavoline Max Life 5W30, based on some recommendations on this thread. Just need to know how much to buy.
Also, I read about some gasket at the drain plug. Hopefully I can reuse the one on there (if it still is). Wont have time to pick that up probably.
Old 08-01-2012 | 09:27 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Google should be able to tell you, I know my 3.0 is 4 1/2 quarts
Old 08-01-2012 | 12:02 PM
Gigolo's Avatar
1999 Acura CL 2.3
somebody told me my car can take 5 quarts and i to have a 99 cl 2.3
Old 08-01-2012 | 03:00 PM
swoosh's Avatar
takin care of Business in
you can check here:
http://www.amsoil.com/mygarage/vehiclelookup.aspx
here is the pdf for a 1999 2.3 CL
http://www.amsoil.com/mygarage/vehic...+ACURA+2.3CL+A
looks like 4.5 qts
Old 08-02-2012 | 03:27 PM
panzer948's Avatar
Hi thanks for info guys. Got the oil changed, rack and pinion installed, outer tie rod ends and even a string alignment. Now just to order new tires and plugs and a real alignment.
Old 08-06-2012 | 11:38 AM
JDM8o9's Avatar
i have a 98 2.3 cl i use 4 quarts of 10w-40 ..but deff check with the dip stick
mada51589
05-03-2022 08:54 PM
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
Allen_442
09-08-2015 06:01 PM
jfman55
09-05-2015 02:55 PM
Quick Reply: Want to change oil today but don't know capacity?
