upgradin bose h/u 2 kenwood
8th Gear
can any1 help me out??? i'm tryin to replace my bose h/u to a kenwood deck. i have everythin wired problem is im not gettin any sound so i was wonderin do i need to have another harness 4 da factory amp? or am i connectin it wrong? does any1 have a wire diagram of the h/u?
Gimmie my points Biatch!
ENGAGE MY VTEC BABY!!!!!!
you can not run the factory amp wth a AM headunit
tap the wires from thw stock harness for the speakers and tap them into the wires for the headunit speaker wires, i cant remember all the color, but i think purple/purplewhite, grey/greywhite, orange/orangewhite and one more but no too sure on the combination
do a search for it or ask the guys in the audio fourm on here and see what you can find out
da factory amp isnt in da trunk its on the side panel on the passenger side flooring.
i like orange juice
i like orange juice
Originally Posted by lomeli3.0CL
got to bypass the factory amp in the trunk!!!! that is what they did to mine when they installed my kenwood.....
blah blah blah
There's no need to bypass the bose amp if you're just changing out the HU. When i first worked on my car audio. I changed out my HU without touching the stock amp and it worked fine.
u need to hook up the blue antenna wire to power the bose amp. i have a kenwood deck on the stock system..no bypassing, there is a blue wire on the harness that needs to be powered by the h/u. use the power antenna wire on the h/u or the amp wire if u have one. it will work fine. why do people keep saying u need to bypass the bose crap. prolly cause they payed some sound shop and got the "it wont work with an after market h/u speech" fell for it, didnt install thier shit them selves and have no idea what thier talkin bout. not talkin shit but if u didnt install it ur self dont give advice about something u have no idea about. i love u guys
Originally Posted by wakeboardfusion
i just rewired mine tonight, i wrote down what wires go where, so i will post a diy later
yup signal is signal to the amp whether its a stock HU or an aftermarket one....... just tap the amp's remote-ON lead (Apparantly its BLUE) to the aftermarkey one, its gonna either be solid BLUE or BLUE/WHITE on the deck harness side. this of course just tells the amp when to turn on/off, itll probably have to be cut off from the car side harness since it probably wont be on the harness adaptor plug for the deck harness
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by 85acura99cl3.0
So I know it's close to three and a half years later, but did you ever post that wiring? If so, where would I look for it?
Medinak12
09-23-2015 07:11 PM
Pegon95
09-15-2015 01:54 PM
