trunk ground?
where is....
trunk ground?
where did you guys ground off your amp to in the trunk?
im having a hard time getting my amp to turn on, so i wanna rule off the possibility of a bad ground.
where is....
Originally Posted by E-man
whatever you do, dont use the trunk latch. i would open my trunk and my amp would shut off lol
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Jesus, I've posted this 20 times, search azn u know better. The best ground in the trunk, and I've used 4 or 5 different ones, is the bolts on the rear strut assemblies
where is....
and a month later...........LOL
i finally found out what i did wrong, my ground was fine. i connected it to the antenna REM wire, well i found out that is wrong on my headunit and that there is a wire with the same exact color and white stripe, turns out the other one is the amp power on wire........
(Mid-Atlantic)
(Mid-Atlantic)
emailnatec
29
09-28-2018 04:27 PM
justin.w13.walker
09-22-2015 02:21 PM
