Transmission cooler install *help*
ok i looked at the diy for it, but it was on the 3.0...since i have a 2.3 is it the same return line? and which one is it? plus anyone that has done it on a 4cyl do i need to get more hose, because it doesnt look like it would reach.
1 or 2? thanks
1 or 2? thanks
hate to say it pimp but youll prolly gonna have to start the car and drive it for a while to see which one is cooler when you touch it. the cooler one is the return line. good luck pimp.
oh man serious? well if i get burned i will know which one it isnt...lol
yep wilp's right. The return line will be cooler than the other. The other line won't be so hot that it will burn you and you won't have to drive for only a minute for the tranny to heat up. Actually I think you can engage the e-brake and then put it in drive and let the car set for a minute and that should do it.
thanks i will try that.
Im No Superman
Originally Posted by hybridnrg
this friday? you doing anything? if not i might want to drop my car off so they can start fitting it.
Sounders FC
mada51589
05-03-2022 08:54 PM
justin7779
12-25-2015 10:33 PM
asahrts
09-04-2015 05:55 PM
30, 98, acura, acurazine, cl, cooler, coolerinstall, cooling, install, installing, line, mdx, tl, transmission, transmsission, tsx
