Tires size on stock 1997 3.0CL wheel
Old 05-02-2001 | 06:35 PM
MontrealCL's Avatar
I am buying some new tires... Decided on the Yokohama H4s as my new set of tires. What I wanted to know is the following: what size tire can I put on my stock rims? I know the stock size is 205/55R16, can I go with something wider?
Thanks to anyone who responds... I plan on buying them tomorrow, so I need to make a quick decision soon.
MontrealCL
Old 05-03-2001 | 01:50 PM
MontrealCL's Avatar
What I REALLY NEED TO KNOW is if I can put 225/55R16 on, and if so, what would the advantages/disadvantages be?
Come on people! I'm buying these tires soon, and need the info.
Thanks,
MontrealCL
Bone stock 1997 3.0CL
Old 05-03-2001 | 02:06 PM
VTEChump's Avatar
Hey
225/55/16's are 25.7" in diameter, and 8.9" in width
(16*25.4) + (2*225*.55)) = 653.9mm --> 25.74 inches.
The stock 205/55/16's are 24.9" in diameter, and 8.1" in width.
(16*25.4) + (2*(205*.55)) = 631.9mm -->24.87 inches
So basically you could have problems with the overall diameter being too large (.8 inch larger than factory)
I have 225/40/18 which are 25.1 inches in diameter and the same width as the tires you want to get and I have no problems with rubbing. I'm also lowered about 2 inches
-98 3.0cl Intrax springs, MAS Italy 18x7.5 wheels, Nitto 555 225/40/18
Old 05-03-2001 | 02:12 PM
VTEChump's Avatar
You might want to try 225/50/16's
24.86 inches in diameter and 8.9 inches in width. These are almost identical to the factory diameter. Might be a little less comfy though with the lower profile.
Hope this helped some
GhostTL09
09-19-2015 01:57 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Tires size on stock 1997 3.0CL wheel
