Tire width on stock rims
Hello everybody,
I have a quick question. I have a 3.0 CL with the stock rims and 205/55/16 tires and I was thinking of replacing them with wider tires. Does anyone know how wide can I go on these rims??? 215, 225, 235 ??? For what it's worth, I know the stock rims are 6" wide. Thanks for the help.
PS What tires would you all recommend? I have Mitchellin Energy MXV4 and this is the second time I get a bubble on the side wall so they're out...
try to surf ebay for a good gset of bridgestone potenza re910's, they are discontinued, but you can usually find a new set of 4 on ebay
They are very sticky and have great wet traction
I read on here that 225 50 16s are about the same circumference as the stock tires. There isn't much clearance above the rear wheels - the upper A arm is about a 1/4 inch from the inside corner of the tire.
