Thought maybe some of you guys would like to see this...TSB
I'm a llama :(
Most of you probably know about THIS site, but I didn't and I'm glad I found it.
Automotive Recalls and Technical Service Bulletins for 1999 Acura CL L4-2254cc 2.3L SOHC (VTEC) MFI.
Provided by ALLDATA
r/zone_tsb.pl?'
Safety Recalls
TSB Number Issue Date TSB Title 03-034 JAN 04 Recall - Ignition Switch Key Interlock Repair
03-034 JAN 04 Recall - Ignition Switch Key Interlock Replacement
02-014 JUN 02 Recall - Ignition Switch Replacement
Service Bulletins
TSB Number Issue Date TSB Title 04-004 FEB 04 Computers/Controls - HIM Module Updating
01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
99-001 APR 02 Body - Power Window is Inoperative
01-037 APR 02 Engine - Coolant Leak From Engine Block
02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
00-037 AUG 01 Brake Disc - Refinishing Guidelines
00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
00-008 MAR 00 Torque Converter Oil Seal Installation Tool
99-050 DEC 99 Cruise Control - Input Test Revision
98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
86-014 JUN 99 Brakes - Brake Disc Refinishing Guidelines
99-022 MAY 99 Front Balancer Shaft Oil Seal Installation Tool
90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
99-011 MAR 99 Remote Audio Switches - Improper Operation
92-009 FEB 99 Drivetrain - Creaking Noise While Turning
99-005 JAN 99 Paint - Codes/Cross References
98-004 APR 98 Audio Unit Anti-Theft Labels
98-005 APR 98 CV Joint Boots - New Band & Tool
90-009 DEC 97 A/T - Warranty Exchange Program
87-015 NOV 97 Audio Unit In-Warranty Exchange/Out-of Warranty Repair.
90-010 OCT 97 Audio Unit Error Codes
86-014 MAY 97 Brake Disc Refinishing.
97-013 MAY 97 New Halogen Leak Detector
97-010 MAR 97 New Fuel Pressure Gauge and Replacement Parts
97-009 MAR 97 A/T Oil Pressure Testing Tools Update
97-001 FEB 97 SRS - Do it Yourself (Owner) 10 Year Inspection
96-039 SEP 96 Power Steering Pressure Gauge
92036 NOV 92 Vehicle Fails State Inspection Emissions Test
[ Select a different engine | Select a different model | Select a different make | Select a different year ]
ALLDATA has obtained this information from the original equipment manufacturers and others and ALLDATA believes it to be reliable. However, ALLDATA makes no warranty regarding the information, express or implied, and accepts no responsibility for the accurancy or completeness of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or misuse of this information, including, but not limited to, any direct, indirect, incidental, special or consequential damages arising out of the use or inability to use this information.
Viton® is a registered trademark of DuPont Dow Elastomers
Loctite® is a registered trademark of Loctite Corp.
Teflon® is a registered trademark of E.I. DuPont de Nours & Co., Inc.
Dexron® is a registered trademark of General Motors Corporation.
Bendix® is a registered trademark of Allied Signal, Inc.
Goodwrench® is a registered trademark of General Motors Corporation.
Helicoil® is a registered trademark of Emhart Industries Inc.
Plastigage® is a registered trademark of AE Clevite, Inc.
Torx® is a registered trademark of Camcar Div. of Textron, Inc.
Motorcraft® is a registered trademark of Ford Motor Company.
Havoline® is a registered trademark of Texaco Lubricants Co.
DEX-COOL® is a registered trademark of ACDelco, Inc.
Optikleen® is a registered trademark of General Motors Corporation.
Lubriplate® is a registered trademark of Fiske Brothers Refining Co.
Copyright © 1996-2004 ALLDATA LLC. All Rights Reserved.
Provided by ALLDATA
r/zone_tsb.pl?'
Safety Recalls
Service Bulletins
the safety recalls were correct-I just took my 98 2.3 in for extented coverage replacement of both regulators ($633) and they replaced the ignition switch and the interlock for free while it was in. too bad they didn't quite get my remote start bypass module put back around the ignition cylinder right and I had to go back and fix it after I left. as for teh other stuff on the list I have no idea-the 1992 tsb's do seem kinda funky though.
AndrewS
19
03-14-2024 06:59 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
