Thinking of colormatching Lips/skirts.
Well. I was gonna take it to a shop, because i was scared that cuz of all the texturing in the lips/skirts, that it would come out shitty if i did it. But i'm thinking with a bunch of sanding, it might not come out too bad. check this out.
http://honda-tech.com/zerothread?id=1635289
what do ya think?
what do ya think?
i say you get it done, our lips paint needs a flex agent added, because its plastic or whatever, in the heat the plastic expands a little, and so the paint needs to expand.. that is why some shops charge a little more $ to do this, the prep is a bitch because they are so smooth
the guy in that h-t thread i posted said go to a local auto finish store, they should have your color code in a can. think they'll have primrose? i dont think honda used it on any other car, so it might be harder to find...
my experience is that the color will be off no matter what. unless the person uses a machine to color match ur current color on the body then the color will no match correctly.
still, i say that u go for it anyways. it wont look bad cuz they are the skirts and they are at the bottom.
i just painted my side skirts, and ww lip at school for FREE...
i have primrose too...i used the PPG paint system, and it looks close enough...
but you do need a flex agent in the paint or else it will start to peel off...
prime your side skirts, then sand it with p400 grit sand paper, clean, paint, then clear it
Originally Posted by $peed])emon
ps. silver is the HARDEST color to match. black, white, red are the easiest. i got pimprose too so i kno...
really? I thought black is the hardest bc of Ive looked at different kinds of blk paint on cars and some of them have blue,green, red etc little glitter in them...I guess you cant tell from far away, but when you inspect it closely...you tell the difference..just my opinoin....I noticed when I looked at my ex's 2004 blk civic...
Originally Posted by 5-speed
would I be able to buy a can of flex agent and then mix it with the paint, or do i have to buy it premixed with flex agent? thanks
rockyboy
Aug 4, 2024 10:35 AM
Rob144
Sep 21, 2015 08:18 AM
nuldabz
Sep 3, 2015 05:49 PM
if you do go right to the shop take them off yourself you should save alittle $$$
