That's odd...
Old 09-24-2003 | 09:15 PM
Blacura's Avatar
-iii-(
That's odd...
So every time i accelerate hard in 1st and 2nd gear my ebrake light comes on and stays on until i let off the gas. This isnt an occasional thing, it happens every time i accelerate hard. This started happening about a week ago.
I checked the brake fluid level and it's fine.
Any ideas??
Old 09-25-2003 | 05:13 AM
q2slinger's Avatar
Its probably the sensor under the brake fluid reservoir cap. There is a little float in there that mearsures the brake fluid level. Check it out, make sure it can move up and down freely.
Old 09-25-2003 | 05:32 AM
jorgev's Avatar
i had that problem with an infiniti i had... there was a quarter by the switch for the e-brake.. that turns the light on.. when i made the car move... it would light it up...
Old 09-25-2003 | 05:48 AM
Leon's Avatar
Re: That's odd...
Any ideas??
mines was doing that, shortly after that started my back brakes started squeaking. once I changed my rear pads it stopped, two months later it started up again, so now I guess my front ones are going too!
Old 09-25-2003 | 11:29 AM
Blacura's Avatar
-iii-(
i just got my brakes changed about 1500 miles ago. that's 4 pads and 2 rotors.
i'll check the float under the cap today.
Old 09-25-2003 | 01:57 PM
DigiBox's Avatar
Lots of JDM parts on my
My CL did that as well. Nothing was wrong either. My brother checked out my cap and told me that it could be the problem. I got a new one, but never put it on. So, if you find out it IS your cap, let me know. It's still new and has never been used.
Old 09-25-2003 | 02:27 PM
Solarian's Avatar
My celica had the exact same problem, my brakes ended up going out completely. I had to replace rotors, pads, brake lines, pretty much everything.
Old 09-25-2003 | 11:40 PM
Blacura's Avatar
-iii-(
ugh i'll try the cap first, and if that doesn't work, i'll take it to the dealer or somethin
atsx1313
03-01-2015 12:30 PM
atsx1313
01-21-2015 09:27 PM
SVTruong
07-09-2013 10:05 AM
TRP
03-30-2013 09:19 PM
jjashaa
10-21-2009 01:17 AM
Quick Reply: That's odd...
