Taking out the bose amp
Hi guys,
I'm sure this has been discussed a hundred times already but I just got a new pioneer head unit and it won’t play any music(The radio turns on and everything appears to be well connected). I have a 97 3.0CL with the Bose system and I was wondering if I could get my new head unit to work just by bypassing the amp in the trunk or would I have to remove all the Bose speakers? Could I keep the same wires? And how should I go about removing the amp?
I’ve searched a lot of the old posts, some say it is possible to keep the Bose speaker, and some say it isn’t. Can anybody confirm which one is actually possible or direct me to a post that explains it properly, it would be very appreciated.
Krazy Dave
I bought the car, and it had an alpine head unit bose speakers and bose amp, i told the guy that i didn't want the head unit. then i put in a 2.0 v 50wx4 pioneer headunit, and that played pretty loud and i was able to use the bose amp and speakers. now i have upgraded to a dvd/cd by pioneer that is 4.5 V with the built in 50wx4 amp that is standard in the pioneer products and i was told that this could not work with the bose amp so i bypassed it and it plays very clearly, there is only a litle bit of distortion at the higher end, but at these volumes, you can listen to it anyways...so when i have money i might change the speakers/bose amp. but at the moment it is more then adequate without
hope i was helpful..
Thanks Krazy Dave,
I'm gonna try to bypass the amp today although I would have liked to have found a way of still using it. I read a post which said something about running the blue power antenna wire from the head unit to power the amp so I wouldn't have to by pass it. I'd like to know if this is possible? And could someone confirm that this is the proper wiring instructions for bypassing the amp.
Right Front Speaker- +Yellow goes to Gray with Blue line
- Brown goes to Blue with Gray line
Left Front Speaker- + White goes to Red with Gray line
- Orange goes to Brown with Black line
Right Rear Speaker- + Blue goes to Brown with White line
- Black goes to Red with Yellow line
Left Rear Speaker- + Red goes to Blue with Yellow line
- Green goes to Gray with wlite line
if you add aftermarket speakers remember to clip the tweeters
Krazy Dave
if i spend alot of money on somehting i like to have it installed profesionally.
i just noticed that you're from mtl...what part and where do you get your stuff done? and i searched, there no pics of your car...you have anything done?
I'm actually from the South Shore of Montreal(St.Bruno). I usually try to do stuff myself but I bring it to the dealership "Les Galeries Acura" or "Acura Brossard" when I have to, I hate the idea of people I don't know touching my car.
The car(97 primrose 3.0 Cl) is stock for now but I am looking for a skirt kit and some new tires for this spring. I'm about to install a new head unit with a Rockford Fosgate 12'' sub and a Clarion amp. Engin mods will have to wait till the end of summer.
Krazy Dave
i can't say i have ever seen a primrose cl in real life! they are very rare up here.
i usually see the black 3.0 most commonly but i saw a champaigne one this morning on the way to work that was SLAMMED! looked like it had no suspension at all! but it was like a 60 year old man driving it!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by FrankCL3.0
Thanks Krazy Dave,
AndrewS
19
03-14-2024 06:59 PM
mada51589
05-03-2022 08:54 PM
Pegon95
09-15-2015 01:54 PM
