stock fog light question..
nippon_wa 2.0
what kinds of bulbs do we need?
I wanna change the color of fog lights.. but don't know which one i should get..
also, I wanna change the hi/low beam too..
i mean.. i want to match with every lights.. headlights, signal, and fog lights to BLUE..(i just changed to philips but it's white.. so.. )
which one should i get?
nippon_wa 2.0
[QUOTE]Originally posted by dustbuster4
[B]Fog Lights = H3
thanks for the reply..
then.. what brand do u think is better for h3? and 9005?(hi/low)
(i just converted 9006->9005)
and.. want to match the color with fog lights.. to blue.. not white..
thanks =)
[B]Fog Lights = H3
thanks =)
Fog Lights = H3
Fog Lights = H3
I went to the dealer and they looked in the computer... no part # either. Called the warehouse, they said the lamp was a sealed unit and you'd have to replace the whole damn thing.
A-CL Post Whore w/N2O
They're fucking stupid!
The bulb type for our fog lights is "H3". Even frickin' Pep Boys carries H3 bulbs. Don't go to the counter. Go to where the 9006 and 9005 headlight bulbs are located (on the rack). There should be H3 bulbs. They usually cost about $9.00 a piece for stock bulbs.
The lamp is not sealed. There are 5-7 screws (you'd think I remember how many after tearing them apart, just last weekend). [The fog lights need to be removed from the car.] Once the screws on the back are removed, it comes off and you have access to the bulb. There is a rubber gasket that fits between the back and the main body of the lamp that helps keep moisture out, but I'd hardly called that a sealed lamp.
Here's a few links to show the H3: http://216.82.69.117/search_results....el=2&subcat=76 (2nd bulb from the top)
http://216.82.69.117/search_results....l=2&subcat=437 (1st bulb)
http://nextcollection.com/html/ORD-L...14384-none.cfm
Picture of the H3 bulb: http://www.italiancarparts.com/acces..._misc/5255.jpg
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
