SRS light help
Old Apr 24, 2003 | 09:31 PM
a-cl2die-4's Avatar
SRS light help
damn SRS light turn on, what should i do, does ne one hea know how to shut it off without spending money
Old Apr 25, 2003 | 08:12 AM
joeshmoe's Avatar
My Home Planet
It's probabaly nothing but you should get it checked out at the dealer anyway. Mine came on after I put in a new alternator and I went to the dealer for my egr valve and asked them to check it out to make sure nothing was wrong. They turned it off for me.
Old Apr 25, 2003 | 09:55 AM
kevandju's Avatar
Mine came on too after I changed the alternator. I was able to reset mine with a paper clip, but from what people say I guess that isn't the best thing to do.
Old Apr 25, 2003 | 06:17 PM
ACURA-C's Avatar
Definitely get it checked out first...it could be serious!!!! However, the choice is up to you:
Here is the procedure
1. Turn off ignition
2. Connect the SCS service connector to the 2pin wire you take out of the drivers fuse box and is now hanging from a thicker harness.
3. Turn on ignition
4. SRS light comes on for 6 sec and then goes off. Before it has been off 4 sec, Remove the SCS connector.
5.SRS light turns on again. Reconnect the SCS service connector within 4 sec of light coming on
6. Light goes off, remove connector within 4 sec after light went off.
7. SRS light blinks 2 times telling you the memory is erased.
8. Turn ignition off.
Old May 9, 2003 | 01:45 PM
Slooo97CL's Avatar
a-cl2die-4, my shit went on too right before my battery died....how did you get urs to shut off?
Old May 9, 2003 | 03:55 PM
ACURA-C's Avatar
If you know its not anything MAJOR.....use my instructions with a bent paper clip. I can host pics tonight of the connector if needed. Its on the left side under the steering wheel, kind of near your knee. The box should be a small yellow box with two wires going into it. Disconnect...and follow instructions above.
It's not too hard.
Old May 9, 2003 | 04:43 PM
superj721's Avatar
I'm rich biatch!
Just remember, if you reset the SRS light yourself...there is a risk of deploying the air bag...it's not common, but it does happen...I had mine reset at the dealership for like $42 (1/2 hour labor)...if I were you I would just go to the dealer...cause it's a lot of $$$ to fix the airbag....
Old May 9, 2003 | 06:58 PM
Slooo97CL's Avatar
It's not too hard.
If you dont mind posting it...thanks much appreciated..
Old May 9, 2003 | 07:51 PM
xdream121's Avatar
my srs light is on now.... my battery was dead for a couple weeks, once i got it runnin again the srs light decided to come on ~~ havent taken it to get looked at yet but probably should.....
Old May 9, 2003 | 08:33 PM
Slooo97CL's Avatar
screw the dealership, unless you have warranty...im not paying 30-40 bucks for a goddamn light that's for sure.
Lets get those diagrams up...and do this
Old May 10, 2003 | 07:36 AM
ACURA-C's Avatar
The procedure I got posted up top on this thread. Im wheel shopping today, sl later, Ill post a pic of the connector and you can follow the instructions above.
Old May 10, 2003 | 08:12 AM
DrDre1443's Avatar
112K and on 1st tranny!
damn! 42 bucks for a half hour labor ouch! thats 84 bucks an hour!! and here in charlotte NC I thought 70 bucks an hour was too damn expensive!!!!
Old May 10, 2003 | 09:33 AM
Slooo97CL's Avatar
i cant see shutting an SRS light taking 30 minutes...ITS A FUCKING LIGHT
Old May 11, 2003 | 06:05 PM
ACURA-C's Avatar
For all the guys that wanted help...I reposted a new thread.
http://www.acura-cl.com/forums/showt...hreadid=102980
Thanks.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
