Squeeky/squeeshy noise in front tire? worn bushings?
Old School Ridin Clean
Listen up Fellow Acura owners and mechanics. MY car is making a squeeking noise everytime my car goes over a bump. I just changed my struts to new kyb agx and the noise is still their.
i did some researched and looks like my bushings may need to be replaced. ANyone have this happen to them?
ENGAGE MY VTEC BABY!!!!!!
i have this same problem, i was fucking around with my front bumper and i noticed it was loose and i was able to lift it up and down but not with too much play but enough to notice the tiny sqweak that it made when i moved it. i dont know if this is my problem but when you go over a bump i usually stick my head out the window to see where the sound is coming from to get a better picture of where to look. does your ride ride differerntly now that it is now happening? i dont know about a bushing but find where its coming from and spray a shit load of wd-40
Check the lower ball joints...does it sound like metallic grinding when you turn the wheel around corners at low speeds?? Id get it checked out. Do a search on this. My wheel actually fell off...
AWD Torque Monster
havent had a prob with my bushings, but seeing how i just got a complete polyurethane energy suspension kit i damn well better not. i got them it from summit racing for like $86. it should be a damn good bang for the buck so i hear. we'll see. im throwin on prokits, koni yellows, and the bushing kit all at the same time so i wont be able to isolate the diff from only the bushings. now if i only had some ST sways.
