squeaky suspension
squeaky suspension
Alrite, so I just installed my lowering springs, the tein s tech on oem shocks, the other week and lately the front driverside has been a bit squeaky and idk why. Everything is bolted on tight and nothing is rubbing. I have noticed that the other springs will squeak but not as much. I was just wondering if you guys think it could be a blown shock or ball joint or do the springs just need to be broken in?
Originally Posted by invisiblewar
i just put my s techs on yesterday with stock shocks (though im 2nd gen) i got a little bit of squeakin too
Fo' SHizzle
I believe they just need to break in, My Tein Basics made like a crunching noise when i first put them on, i just think its the stiff steal wearing in a lil. If the squeaking leads to a difference in ride then I would worry, until then id say try to grease your shock to relieve the friction from the piston, might take some of the squeak there. WD-40 seemed to be a easy, fast but short term fix for mine, but iv had the basics on my car for about 10k miles and they no longer make a noise at all.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
They need to settle for sure. If they keep squeaking you can put bump stops on them, it could be your bushings creaking too
Turtle Charged, Biotcch!!
Try this:
https://acurazine.com/forums/showthread.php?t=188384
Go to Home Depot and buy a tube of Silicone grease (NOT the Marine or Metallic ones). I've found that it's cheaper and the pointed nose of the tube let you apply the grease without getting your arms covered in it.
Wow prolly should of searched... my bad.
Thanks sleeper. I hit everything up wit silicone and the squeak went away. It was definately my upper control arm bushings. Its all good now.
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
