Squeaking sound when break gentlely
7th Gear
Hi everyone. I need some help from you guys.
I have a 97 CL 3.0. The car starts to make a squeaking sound from time to time when I apply break gentlely from about 2 years ago. I asked dealer to look at it back then but they can not reproduce it. And the break pads were ok.
But recently I can hear this sound more often. Is there somebody else on this board who has experienced the same kind of problem? I really want to know other people's experience, so I could bring it to a private garage for repair or do some brake work. I don't want go back to the dealer since they rip me off everytime.
Thanks in advance.
Thanks in advance.
Bent = #1
Yea man...that is a safety feature that means you have 10% of your brake pad left...nothing special now...just get ur brakes changed within a month or so...that is if you can take that damn noise...it pissed me off after a couple of days so i had to get my brakes changed right away..
CL'S
CL'S
7th Gear
Thanks for your reply.
I suspected that first. But the dealership says the pads are ok after the many inspections in the $500 3 years service. Now I am wondering if they did any brake inspection at all. One clue is that they charged me 5 hours' labor but I got the car back after 3 hours. I don't think I will ever go back to them again.
I will have a mechanic check it out.
[QUOTE]Originally posted by hornyleprechaun
[B]Yea man...that is a safety feature that means you have 10% of your brake pad left...nothing special now...just get ur brakes changed within a month or so...that is if you can take that damn noise...it pissed me off after a couple of days so i had to get my brakes changed right away..
Its the safety feature warning that the pads are in need of replacement. Don't rush to change them right away, the indicator might only need to be adjusted, I'm having the same problem on my rear breaks, driver's side only. It's sooooo annoying.
yeah i posted bout that noise a couple of months ago..... i took it to acura and they checked the pads and said they were all good so i drove it like i usually would instead of being easy on the brakes.... the next day the noise got worse and wouldn't go away so i brought it to some friends at a shop and they told me that it was just some parts that needed to be replaced. when they took it apart they said that i needed pads so they replaced those too and since then it's been fine. what i wanna know is how acura is gonna charge u 5 hours labor and do nothing to fix the problem.....? u actually paid that? well good luck.
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
lanechanger
10-13-2015 10:56 AM
