Squeak
Originally Posted by SilverCL97
take it out..
weight reduction, ayougo style..
little
anyways, the countdown is the days till Englishtown 2006 where the 2.2s face off against the 3.0s ....aka me vs Subbuzz
and finally put all the 3.0s to shame
:ibthisturnsintoanother2.2vs3.0pissingcontest:
07 tl-s in
Originally Posted by 2.2Clean
That front passenger seat comes in handy if you know what I mean. Im tall and cant fit in the back seat. Also what is your countdown for?
little
The Hefty 2.2
you guys are useless!!! haha.... I have the squeaking too... I'm pretty sure it's a loose bolt for the passenger seat, but i haven't been able to pinpoint exactly where it is, or what bolt it is. If anyone knows... help this guy out!!! and me too!!!
CL 4 LYFE
1 Post
its kinda hard to tell what is squeeking from the internet. need more info like if your sittin in the seat gettin rocked by a 4'10 250lb chick and the seat starts squeekin.. but even then it could be the friction from the chick... but what does the squeek sound like? does it sound like squeeeeeeeeeeeeeek squeek or eeeeeeeeeeeeeeeeeeeeeeeeeeeeee'errrrrrrrr ???
WTF is going on?
its kinda hard to say if we dont know here its comming from and what it sounds like etc..
just turn the music up louder
ur as welcome as cancer
Yah, so for a while my passenger seat was squeaking, then it wouldn't lock in place HAHAHAHAHA - got that fixed REAL quick. Look out though, fix it now 'cause it'll only get worse!
Peace, Love & Acura
From what is being described, it sounds as though the seat back is rocking. If that is the case, get some powdered graphite and squirt it into the locking hub at the base of the seatback. You may need to remove the plastic cover to do it. And if so, be gentle, the plastic is fragile and can break easily. I say to use the graphite, because it is a dry lubricat and won't collect dirt and turn nasty like WD-40 and spray silicone. Although, if you can't get the graphite, spray silicone will work. Just be sure to wipe away the excess spray. Graphite can be purchased in a tube at most lock and hardware stores. You might also check the rail bolts, but I don't think that is your problem.
Good luck.
Good luck.
