some pics of koni/prokit install so far
AWD Torque Monster
still waitin for new bolts and bushings for the rear from acura carland. damn they take forever. n e ways here is the front
bout 1/2" wheel gap if that. this is using prokits with koni yellows se on the lower perch from the side of the car u cant see the gap at all so im hopin when i drop the back the front will raise a little. right now it looks a little tucked and i want tourning look not ricey civic so im not sure i might set the koni back to original position
the front end of my car is about 4.5" off the ground. the camera messed the angle a little so it looks like 5
heres some of the energy suspension new bushings. so far i replaced the upper bushings, coil spring isolators, and sway bar end links. im waitin for the summer to replace the upper and lowere contol arms as awell as the lower shock.
hey man how'd u do your lower grill?
did you just zip tie em onto the front? cuz i did mine but i put the grill on the INSIDE lol
so its hard to see and it doesn't look as nice
I want to change it around, have any advice?
thanx!
oh and my H&R Springs just came in, but i think im going with a professional install cuz no access to spring compressor =|
thanx!
Moderator Alumnus
you only need the compressor for the stock springs. the aftermarkets can be pushed down by hand.
which H&R springs did you get? if you got the race springs........ man are you gonna be hating life.
Midnight Marauder
I see the headlights are still out, guess your still working on those bmw projectors. Prokits/Koni Yellow is a great combination, I had that setup in my old accord for almost 6 years , never had a single problem, rode great, handled great. looked great!
oh i could just push it down by hand?
I got sports lol i kno racing would make everythin like crap =|
hmm i might consider self install then
time to do more research lol
AWD Torque Monster
i dont know how u could tell my headlights r out. those r the bumper lenses that are missin but n e ways im surprised u missewd my post on the HID project
http://www.acura-cl.com/forums/showt...threadid=90598
Work safe avatar bish :D
If you look at the pic really quick it looks just like the headlamp assembly, but that would make the car be slammed on the ground
fellow MASShole
dayum those koni yellows make a huge difference .. now iv'e seen prokit setups go from 4x4 look to know this ... ur almost as low as i am and im on the sportlines make sure to post pics of the back .....
AWD Torque Monster
im going to leave the rear yellows in the original position and drop it. hopefully the gap will be a little bit higher in the rear. just as long as the rear isnt lower than the front ill will be happy. im still waitin on blots for the rear. acura carland is takin 4 EVER!
Midnight Marauder
AWD Torque Monster
found out order never went through! damn! im so held up. cant finish the HIDs until the car is dropped finally so i can aim them. cant put bumper on without the lights on. got my car up on jack stands. oh yeah and the damn bolt still wont come out of the bushings. i got both shocks off, but the bolt is still stuck. now im going to torch the bushings out and i will have to replace the bushings now. one thing after anohter after another. i cant wait to be done. a 1 day project has taken a month so far
i just installed my shocks on saturday with my brothers and it would have taken just over 3 hours including our pizza break if we didnt have to go find a bolt for one that was too rusted to be put back on. its not too hard of a project and you get the satisfaction of knowing you did it yourself. . if we had a lift instead of doing one wheel at a time on a jack it would have taken much less time.
05 STi White/Gold
have a question for u. how many fingers gap did you have in the front and back before you put the konis in? i have a 3 finger gap in front and a 2 finger gap in the back. if it will reduce both to a one finger gap, it's probably worth it. also, i'm getting 18s soon. will the gap be reduced or largened? thanks alot!
IgotCLass
How much did you pay for you koni yellows? the cheapest i have found so far is www.shox.com $515 with free shipping
i passed up an offer, $250 for tokico blues
hope i don't regret it
but so far the springs kick ass no problemz at all! just drive a lil slower and its alllllllllllll good
05 STi White/Gold
i'm not sure if you saw my question earlier... but i hope u can help. u have a 2.2 right? how many fingers gap did you have in the front and back before you put the konis in? i have a 3 finger gap in front and a 2 finger gap in the back. if it will reduce both to a one finger gap, it's probably worth it. also, i'm getting 18s soon. will the gap be reduced or largened? thanks alot!
AWD Torque Monster
i wouldnt with bother a complete bushing set, heard of too many probs, and install is a bitch, however i do reccomend changing the coil pads, upper and lower shock busings, sway bar and endlinks and ull get less body roll, better handling and the ride wont get too harsh. jus little bit, but more than worth it.
i never had the prokits with oem shocks only konis on the lower perch. i havent dropped the rear yet either, so i dont know the final height. but the front is about 1 finger gap and with my lip my front end is about 4" off the ground however when i drop the back i expect the front to lift about 1/4"
DiamondJoeQuimby
09-10-2015 11:40 AM
alan_rich
09-09-2015 11:38 AM
