Rubbing Brakes?
An Official Cl Whore
Rubbing Brakes?
Whenever I stop I get a rubbing noise from the drivers side wheel area. I can feel it from the floorboard. I just had the brakes and suspension parts inspected, came back fine, no torn boots or anything. Just wondering what it might be? Thanx
Scooby Guru
Maybe you've got a rock stuck in your pad? Try driving backwards with the brakes on for a bit, sometimes that dislodges them. Or pull off the pad to see what's rubbing!
check ur wire harness for ur ABS system to see if any torn wires. It could be that the wires are torn and are touching the frame of the car creating a "signal" or "ground " for the ABS motor to work .
