Replacement tires for stock rims
It's time to get new tires.
I was looking at getting 215 55 16's but it seems that that size, along with standard 205 55 16's are the most common and therefore more expensively priced. Then I looked at 215 60 16's and it seems that this size is bit less common and a bit less in price. Obviously, the profile will be taller, but will rub or anything? Anyone use this size?
I'll take a look at those. Is your's lowered....how is the gappage?
Kumho ECSTA Supra 712 V-rated in that size seems to be the most expensive. I guess it varies with the profile.
215 50 16 - $81
215 55 16 - $67
205 55 16 - $62
215 50 16 - $81
215 55 16 - $67
205 55 16 - $62
Marine Gulf War Veteran
aiight i'm goin to ask a stupid question...in 205 55 16's...wat does the 205 and 55 stand for when talkin about the tires size ...obviously 16's are 16's...
Originally Posted by damond
205 55 16
205 is the width in millimeters
55 is the height of the sidewall, determined by percentage of the width (55% of 205).
my car is lowered with eibach springs. looks good with the stock rims, but the 50 sidewall looks nicer than the 55 and holds a little better also, i think. is this what you are always going to be riding on? if they are your everyday tires, spend the money. get some michelins or goodyears. try tirerack.com, they're pretty good.
