removing seats
Former Sponsor
Two 12mm front bolts. Two 12mm rear bolts. Lean the seat outward. Unplug the seatbelt sensor and seat heater plugs. Pull the seat up and out in the folded position. Be careful not to scratch your door panel with the rails. Good luck.
Why are you taking your seat out again?
Ok. I figured WTF, I got nothing much to loose. There is a small door hiding a small slotted head sheet metal screw holding that plastic housing down. Pop open the door, remove the screw, and pull up, wiggle, and that housing will come off revealing the bolt holding the seat on that side. Easy.
My front seat was rocking because this bolt was loose. I tightened it down real good and now no more rocking.
Replacing the plastic cover took a bit of wiggling but really its no problem.
Rich
Rich
Former Sponsor
Rich
Rich
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
