Removed Badges....
I would love to do the same thing. Can you give me directions on how to do it. I don't want to be left with a scratched trunk or holes or some other stupid crap that i am fully capable of doing.
97 Acura CL3.0 Prem.
To remove the emblems, all you really have to do is to slowly pull it off with your hands. Then there will be some remaining pieces of the sticky tape thingy which can be easily rubbed off with you finger or a rubber eraser? And the "A"cura emblem in the center has two holes behind it.
You could always bondo and repaint it . Anybody know a better way then this?
'98 2.3CL w/Type-R Air Dam and bright lights and stuff. I dont know what else, it came like that.
The easiest way to remove the Acura and CL emblems is using dental floss, and then bug and tar remover to get rid of the rubber.
The center emblem comes off very easily, and then there are two white plastic plugs which the emblems sits in. I removed these plugs leaving two holes.
I then put molding tape inside the trunk to cover the holes and prevent water from leaking in.
I then used body-color matched paint to paint the molding tape from the outside.
Granted the holes are still there but I have prevented water from going in and the holes are not noticeable from afar.
Hope this helps...WORD!
hey guys, i removed the badges on the back of my CL, but the rubber and glue are still there. I got bug and tar remover, but it doesnt work on the rubber, but im sure it will remve the residue from the glue. Any ideas on how to remove the rubber?
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
<font face="Verdana, Arial" size="2">Originally posted by xerothermic:
hey guys, i removed the badges on the back of my CL, but the rubber and glue are still there. I got bug and tar remover, but it doesnt work on the rubber, but im sure it will remve the residue from the glue. Any ideas on how to remove the rubber?</font>
gunkoff
I pulled the badging off and left the A. I just used the brute forge method after going to the car wash, then rubbed on some gunkoff, or adhesive desolver stuff. It looks great, the only problem is that the paint underneath the lettering is not faded at all. so it is a slightly different color red.
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
