Recommended Service Intervals
My dealership sent me something in the mail for 53,oo miles. But, I found this service interval from Parkside Acura. Does this seem about right.
To keep your Acura running at peak performance, we recommend adherence to the following maintenance schedule, in accordance with the manufacturer's specifications:
At 3750, 11500, 18500, 26500 miles and every 8000 additional miles thereafter:
Engine oil and filter change
Check cooling system hoses and fluids
Lubricate all hinges and door strikers
Check and adjust all tire pressures
Check tire wear and condition
Inspect the exhaust system
At 7500, 22500, 32500 miles and every 10000 additional miles thereafter:
Check and replenish all system fluids as needed
Check and inspect all engine belts
Inspect front and rear brake systems
Lubricate hood hinges and latch assemblies
Check and adjust clutch, as needed, on vehicles with manual transmissions
Rotate tires and set appropriate pressures
Inspect exhaust system
At 15000, 45000 and 75000 miles:
Engine oil and filter changes
Lubricate all door hinges and strikers
Replace transmission fluid
Check engine valves and adjust as needed
check air filter and replace if indicated
Inspect ABS on vehicles equipped with same
Clean and lubricate front and rear brake systems
Check front axle boots for leads or damage
Replace A/C intake filter
At 30000, 60000, 90000 and 120000 miles:
Inspect all engine fluids and flush respective systems
Flush cooling system and install new coolant
Inspect and adjust all belts
Change air filter
Replace fuel lifter
Inspect, clean and lubricate front and rear brake systems
Replace spark plugs*
Replace distributor cap and rotor where applicable
Check front alignment **
Flush and replace transmission fluid
Adjust parking brake
Inspect ignition wires and replace as needed
Flush brake fluid and instill new fluid
Inspect steering system
]Inspect and lubricate suspension where needed
Drain and replace differential fluid
We strongly recommend a timing belt change be performed between 60,000 and 70,000 miles.
We also suggest replacement of the ABS high-pressure hose at
60,000 miles, as preventive maintenance, with an ABS flush.
* Legend model years 1986 through 1990 require spark plug replacement every 30,000 miles.
Model years 1991 and later require spark plug replacement every 60,000 miles.
** Alignment is optional and available at an additional charge.
Change air filter
Replace fuel lifter
adreano17
09-29-2015 08:48 AM
