r my brakes F*cked??
on my way home acouple minutes ago my brakes fucked up huge
when i went to slow down i had to push down all the way instead of pushing down a little bit as i usually do...
..could it be that i just have to refill the brake fluid?? ...wat do u guys think it is??..my ABS and E-Brake have been on the last couple of days but i thought that it was only because it was soo cold (-35)
hopefully its nothing too serious because i was planning on buying some coilovers in the next few weeks..
that happened im my legend..
there was a leak in the brake cylinder.. i had to fill my brake fluid every week... try checking the cap.. maybe its not on tight enough..
or it might even be your pads.. have u been braking alot lately? maybe u worn out all your brake pads.. thus u have to push it harder..
1.) check your pads
2.) check your pressure in your brake cylinder (and fluid level)
1.) check your pads
Originally Posted by ajbent86
more then likely, you need to replace your master brake cylinder.....
you either have air in your brake lines and/or you could also be leaking brake fluid. you should check it asap especially the type of weather we're getting here latley around toronto. try going to canadian tire or a small garage
7-30-05 First Place STS!
Originally Posted by SilverCL97
well i put some brake fluid in this morning and the ABS and E-brake light went off but the brakes are still messed...
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
