question regarding hooking up shock sensor to alarm??
guys,
i need help badly.i started the process of hooking up a shock sensor to my alarm today and i am so confused.below i listed the color wires on the sensor,i just need to know this>>>
-i hooked up the black wire to the black wire(12 pin connector)
-i hooked up the red wire to the white wire(12 pin connector)
thw diagram that came with the sensor reads this:
red wire(+12vdc)
black(-)ground
blue (1st stage(-)output
white(2nd stage(-)output
my question is this,where the hell does the white and blue wire go.i hooked the blue to a light green wire on the 18 pin connector and the white to the brown wire but all i get is the warn away beep and the alrm does not sound----please,please,please help cause i hate having my car apart. private message me asap--thanks--joe--onedayzpay
red wire(+12vdc)
black(-)ground
blah blah blah
You don't need to hook up the stage one (warn) cause even when the car is on, and u hit it, the warn will come on. Just hook up the Stage two (alarm) to the hoodpin wire. I forgot what color is that. And it should work fine. If Not, do a search on the forum, there's more info on it.
Here is the Acura CL alarm pinout http://polaris.umuc.edu/~jwen/AcCLSecurity.htm
You can also check here http://www.acura-cl.com/forums/showt...t=SHOCK+SENSOR
and here http://www.acura-cl.com/forums/showt...ht=Shop+Manual
Hope that helps you out.
09-17-2015 09:01 PM
