Question and Answer Thread
Old Dec 3, 2009 | 08:40 AM
  #401
ljohnson02's Avatar
5th Gear
03-05 Honda Accord has the J30A4, pretty much same motor that is in the CL, 03-05 Accord uses the 5sp Auto. I understand ecu, wiring harness, and shifter assembly, may not fit. However fitment for the transmission shouldn't be an issue, what do you think?
Old Dec 3, 2009 | 09:25 AM
  #402
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Tranny mounts will be different
Old Dec 6, 2009 | 12:11 AM
  #403
spyro's Avatar
GAM3 OVR !!
raising my car back up to stock, just wanna make sure that the " 4cyl springs are the same as the 6cyl springs" ....Is this correct?
Old Dec 6, 2009 | 12:14 AM
  #404
(Mid-Atlantic)
Nope, 4 cyl springs have dif spring rates
Old Dec 6, 2009 | 12:17 AM
  #405
spyro's Avatar
GAM3 OVR !!
ok...i'm not too concerned about how it rides i just wanna make sure they fit perfect.
Old Dec 6, 2009 | 08:11 AM
  #406
(Mid-Atlantic)
They should fit the same as far as I know, just letting you know they're rated different because of the weight difference, just the front springs would be different
Old Dec 6, 2009 | 11:29 AM
  #407
South Jersey CL's Avatar
can the stock stereo read mp3 cds?
Old Dec 6, 2009 | 12:47 PM
  #408
saiko_cl_duck's Avatar
do you have bose? if so, mine has, but has trouble doing it occasionally.
Old Dec 6, 2009 | 06:14 PM
  #409
DoubleSh0t's Avatar
When replacing the hood locking assembly, would I need to replace the cable that runs in the cabin for the hood release?
Old Dec 6, 2009 | 09:10 PM
  #410
teh CL's Avatar
not unless it's snapped, dunno why else it would have to be replaced..
Old Dec 6, 2009 | 09:59 PM
  #411
DoubleSh0t's Avatar
Okay, I just wasn't sure if it could be removed from the mechanism.
Old Dec 6, 2009 | 10:02 PM
  #412
(Mid-Atlantic)
nope, you just need to loop the cable the same way as it was in the other hood release
Old Dec 7, 2009 | 07:25 AM
  #413
nope, i have the standard stereo.
Old Dec 7, 2009 | 08:36 AM
  #414
(Mid-Atlantic)
The oem stereo can read most burned CD's, but was built way before MP3 format was supported on car stereos
Old Dec 7, 2009 | 04:18 PM
  #415
spyro's Avatar
GAM3 OVR !!
ok need a possible quick answer if possible please.....i haev a 98 3.0 and everytime i press the pad to lock the car only the passenger side locks. The driver side engages and immediately disengages. i took off the panel and when i try to do it manually it does the same i lock it but it goes back to unlock by itself. Anyone know what the hell is going on ??
any help would be greatly appreciated !! THANKS !
Old Dec 8, 2009 | 08:33 AM
  #416
(Mid-Atlantic)
Sounds like your door actuator is on it's way out, there's a diy on how to replace it on here
Old Dec 8, 2009 | 08:33 PM
  #417
yeah i play burned audio cds all the time, just wanted to know about mp3 cds. thanks guys.
Old Dec 10, 2009 | 05:13 PM
  #418
mattastick's Avatar
Is the CL and a 4 door Accord dimensionally the same in terms of the interior? Specifically, I'm talking about the area between the B-pillar and the trunk...
Old Dec 11, 2009 | 01:23 PM
  #419
Whenever I shift into first (when i start moving), i feel a slight shake from the clutch, as if its slipping a little. and sometimes when i shift into second, even when i give it plenty of gas, the car will shake pretty violently. whats the deal here? is my clutch on teh way out, or bad motor mounts, or both? or something else?
Old Dec 13, 2009 | 10:13 PM
  #420
mattastick's Avatar
At what RPM does it happen? And what do you define as "plenty of gas"? Mine does this as well, if I let the RPM's drop too low (800-1200) while I'm letting the clutch out. If I keep the RPM's up near the 1500-2k range though, it's fine... Just maybe a thought. Also, where are you shifting from 1st to 2nd? That would probably determine whether or not it'll do the same thing in 2nd gear...
Old Dec 14, 2009 | 09:03 PM
  #421
when i shift into second i usually give it anywhere from 1700-2500 rpms, and it shakes pretty violently, but only sometimes.
Old Dec 16, 2009 | 06:56 PM
  #422
Stumax's Avatar
9th Gear
All the pictures are gone
Hey everyone, my question why is it that all the fixes that I would want and the DIYs and mostly everything that I would need to see a picture of, there is no picture. There are DIYs not even a month old and the pictures are gone.
Old Dec 17, 2009 | 08:50 AM
  #423
(Mid-Atlantic)
Which diy's are they? If they were made by me it's because my web server crashed
Old Dec 17, 2009 | 03:33 PM
  #424
fliplyricist1's Avatar
Staggered 1st Gen
Does anyone have any experience with those ebay aftermarket 'oem style' fenders? Need to replace my stock drivers side because of too low offsets and was tucking tire and creased the metal a bit...just curious how the fitment is on those aftermarket ones or if I should just try to locate an oem one instead and repaint
thanks
Old Dec 17, 2009 | 10:35 PM
  #425
TicaL's Avatar
Anyone know whats the differance between a f23a vtec and a F23a4 ulev vtec?
Also if i swaped a f23a4 what would i have to swap over?
Old Dec 18, 2009 | 04:43 AM
  #426
DaInFaMMuS1's Avatar
I had an aftermarket one on my passenger side and it fit fine. The only problem i had was that i didnt get the frame straightened out completely after the accident so my headlight sat in a funny position, but that's being addressed. The fender itself was fine for fitment.
Old Dec 29, 2009 | 12:30 PM
  #427
VS70's Avatar
Yearly changes question - what were the yearly changes to the 97-99 CL? Here's what I have so far:
97 - debut
98 - 2.2CL becomes 2.3CL, new grille, steering wheel audio controls added
99 - 2.3CL gets std. leather upholstery
Are there any others?
Old Dec 29, 2009 | 01:23 PM
  #428
(Mid-Atlantic)
I think all of the 99's came with the premium package, it was an option for 97, and 98
Old Dec 29, 2009 | 02:01 PM
  #429
mitch14's Avatar
CL in lawnmower status
from what i understand '97 2.2's come with leather, but only year/model where they are not heated...right?
98-99's get different center console woodgrain accenting, around the radio, shifter etc, looks a lot nicer IMO
also a bunch of different wheels, 97 2.2's is the fat 6 spokes, 97 3.0's is fat five spokes, can't remember what the other styles correlate to
Old Dec 29, 2009 | 02:16 PM
  #430
(Mid-Atlantic)
each 4 cyl and 6 cyl have different wheels for each year, those have been posted
Old Dec 29, 2009 | 11:55 PM
  #431
mattastick's Avatar
Don't forget that the 98-99 console not only looks better, but it is much easier to disassemble. I've taken apart both (although the 97 was the Accord equivalent) and my 98 takes less than half the time...
Old Dec 31, 2009 | 05:53 PM
  #432
Kyanite's Avatar
Stay Low Pro Kinfolk
I know the front bumper bulbs are 7440, and I'm trying to change em, because after I got my clear corners I saw they were some ugly yellow color. Gonna buy some White LEDs I think, but I had a few questions.
I've heard if you buy LEDs that they flicker uncontrollably faster than normal is this true?
Then I heard somebody say that they need resistors or else it can mess something up, but the ones that are on superbright come with em I think. Can anyone let me know if I need some special ones or if these ones are fine.
http://www.superbrightleds.com/cgi-b...ecs%2F7443.htm
And if theres any problems with these let me know n direct me to some good ones
Old Jan 1, 2010 | 10:38 AM
  #433
(Mid-Atlantic)
yep they will flicker, you need resistors or a new relay
Old Jan 1, 2010 | 03:25 PM
  #434
Kyanite's Avatar
Alright, so if I buy those 2 LED bulbs I mentioned above and I get these here:
http://www.v-leds.com/BlinkerWarning...-p4783296.html
My problems should be fixed and I should be good.
Anyone Object?
Old Jan 2, 2010 | 12:07 AM
  #435
(Mid-Atlantic)
nope sounds good
Old Jan 2, 2010 | 10:33 AM
  #436
bRunCL's Avatar
Anyone Object?
In most states your turn signals must illuminate orange/amber. If you have the super white or clear leds you could get pulled over.
Old Jan 2, 2010 | 05:00 PM
  #437
Kyanite's Avatar
Just checked some laws regarding turn signals in the front for Oregon and it states... "Front turn signals may be white or amber". If anything, the ones I got on now would be illegal, they're a yellowish-tan color.
Old Jan 2, 2010 | 11:44 PM
  #438
mitch14's Avatar
thinking about storing the cl for winter instead of trying to quickly sell it now.
anyone know what has to be done to the cl, in order to store it for about 4 months or so, i'll prolly be storing it outdoors and not starting it at all in those 4 months, i'll probably take the battery out, but i dunno if i need to do anything else (temps of -40 or more outside most likely)
just thought i'd ask you guys as you'd prolly have more experience with this kind of stuff
i know you do it with your cl all the time Chris
any help is greatly appreciated
Old Jan 3, 2010 | 01:23 AM
  #439
(Mid-Atlantic)
Stabil, learn it, love it, just bought a bottle today at walmart. Best thing to keep your car starting. I would still start it once a week if u can, but stabil is the best for keeping your system clean and gunk free, and starting everytime
Old Jan 3, 2010 | 01:59 PM
  #440
mitch14's Avatar
alright, i'll look it up, thanks Chris
and i would start it all the time if i can find a place closer to home, but since all the space i can think of (my house or family member's houses) are all full, i'll prolly just store it at someone's cabin or something out of the way
