AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   1G CL (1997-1999) (https://acurazine.com/forums/1g-cl-1997-1999-56/)
-   -   Question and Answer Thread (https://acurazine.com/forums/1g-cl-1997-1999-56/question-answer-thread-732691/)
97BlackAckCL Jun 23, 2009 03:49 PM
This thread was requested by members of this forum.
This thread is specifically for asking and answering questions about your car.
This thread is meant for 1st Gen CL related questions only, this is a car forum, use it to ask questions about your car.
No off topic conversations will be allowed.
The format of this thread is that someone asks a question that they need a quick answer to. People can chime in with HELPFUL USEFUL ANSWERS
This thread will be monitored and moderated, however don't make it difficult for us. We don't want to have to keep this thread clean or have to be deleting useless BS or rambling off topic discussions.
If you don't have anything to add to the current running discussions or questions,
do not post here or you will be in violation of the rules and dealt with accordingly.
No parts requests
Abuse of this thread will lead to closure or deletion.
Please respect your fellow members and please respect the rules, let's make this a useful resource.
Post a question that you need to know, and we can respond back with answers, please read and obey the rules
DaInFaMMuS1 Jun 24, 2009 06:44 AM
i'll start it off I guess.
Does anyone know if there is a manual steering rack of any other honda that us members w/deleted power steering could use instead of the power rack? Or is that impossible unless custom made?
Anhedonia Jun 24, 2009 01:31 PM
^ after doing some looking into that.. my best guess would be to try and find an accord one from the pre-power steering days. i think an 87 and below should do the trick if what i was looking at is correct. what i couldnt find is if there was ever an F/H that had non power steering.
1slo23 Jun 24, 2009 02:58 PM
For a CAI, what size inlet should the filter have to attach to the pipe? I need to know so I can order the K&N along with the ebay intake. Thought I asked before, but not sure.
Josh99CL Jun 24, 2009 03:18 PM
It should be 3"
It doesn't say anywhere on the ebay page?
shnee Jun 24, 2009 04:09 PM
They make them in all different sizes. Be careful, I was about to order a filter for my pipe, but decided to double check it to be sure. It was 2.5", not 3" like I assumed. If you're ordering the pipe and filter from different places, make sure it lists how big it is in the description.
mitch14 Jun 24, 2009 07:51 PM
how do you know if your clutch is going? is there certain thigs to watch for... i think mine is the original or the 2nd only
Mike86 Jun 24, 2009 07:55 PM
the main sign is slippage, and the easiest way to test for it is to apply the brakes in 2nd or 3rd gear at around 3k rpm and floor it but push on the brakes to the point of slowing the car down and lowering the rpms, and if the rpms raise then it's slipping and on it's way out.
Another possible sign would be if it chatters alot upon taking off
Oh btw I'm on the original clutch at 155k miles and still smooth with no slippage
TopGunEV Jun 24, 2009 08:34 PM
Is the inlet size on our throttle body 3 inches, and is there a power difference when getting a 2.5 inch intake opposed to a 3 inch? I KNOW MORE COLD AIR IS BETTER.
irresponsiblekid Jun 24, 2009 09:07 PM
what distributor & ecu should I look for for the non-starting jdm f22b swap in my car currently? lack of CPS down low under the timing belt cover tells me the block is obd1...
and can I mod / hack the wiring on my CL dizzy? if so, how?
Gnate Jun 25, 2009 12:25 AM
^ Hit up a tuner shop I bet they could help you out
97BlackAckCL Jun 25, 2009 08:11 AM
I believe the Tb on a 3.0 is 3" I have a 2.75" CAI tube on mine with a 2.75" filter and bypass valve, 2.75 is pretty standard for our engine
shnee Jun 25, 2009 03:07 PM
Maybe I meant 2.75, not 2.5. This was a while ago :tongue:
TopGunEV Jun 25, 2009 03:37 PM
OK Sounds good, so if I order a AEM v2 for our car, it is recommended to say f--- it to the aem filter that comes with it and just by a K/N 2.75 in Cone to prevent hissing. I'm having that go on right now and cleaning it didn't help. Sounds like a mini turbo lol...+15 HP
97BlackAckCL Jun 25, 2009 03:39 PM
AEM V2 is a waste, just get an ebay intake and put a k&n filter on it
Gnate Jun 25, 2009 04:23 PM
Best advice you'lll ever get in regards to cold air intakes. (not kidding)
If you spent $100+ on an aem or injen you'd really regret it later once you realized that all of the piping is exactly identical to that of ebay. It is the filter that matters.
irresponsiblekid Jun 25, 2009 05:52 PM
what's the stock 2.2 ECU and can / do I need to flash it to p39 to match my jdm f22b
I think i need to convert to obd1 does that mean new ECU automatically?
irresponsiblekid Jun 25, 2009 06:20 PM
Just called the one shop I know is still open locally
"Yeah, tow it in and we can get it running for about FIVE HUNDRED"
the fuck outta here the longblock was 375
rice_plz Jun 25, 2009 06:58 PM
does 215/40/16 fit our cars i wasnt sure from the nob guide thanks
f22vtec Jun 25, 2009 09:23 PM
is any one good with the bpi velocity stacks? i heard you need a bigger filter which i got for free from my friend its 3 or 3.5 inch
spencer_homer Jun 26, 2009 03:45 AM
yeah depending on what wheel size. 16x8?
shnee Jun 26, 2009 03:13 PM
Yes, you need a filter that has a 6" opening. If you want a K&N filter, BPi offers the velocity stack and filter together. Personally, I was looking into dryflow filters. I'm sick of this oiling shit.
Mike86 Jun 26, 2009 08:07 PM
Yes, but it will be quite a bit smaller in overall diameter and will look dumb without a substantial drop, and even then I'm not sure it will look good.
And that tire would fit a 16x8 or 16x7 wheel, and it would even fit the stock 16x6 but it's a bit of a stretch, I've put 225 series on 16x6 before though and ran them for thousands of miles with no problems. In fact, I think someone on here is running 225/50/16s I believe on stockies, can't remember who though.
A good size for calculating tire diameters between different sizes is:
http://www.miata.net/garage/tirecalc.html
spencer_homer Jun 26, 2009 08:55 PM
ive got 225 55 16's and a pretty subtancial drop
old pic
http://i41.photobucket.com/albums/e2...r/car025-1.jpg
f22vtec Jun 26, 2009 09:03 PM
yea i have an aem dry flow now
Mike86 Jun 26, 2009 09:05 PM
old pic
Do they ever rub when cornering or anything? I'm looking at buying some used rims on 225/40/18s from a guy if he's still got them, but I'm not dropped (yet)
spencer_homer Jun 26, 2009 09:15 PM
no not really. ive got mm of clearance. but ive got 2.2 f 2.0 r but its used and i think its sagging lower than that
1slo23 Jun 27, 2009 12:31 PM
Anybody on here have experience with Skunk2 suspension parts? I'm looking at their Sport shock kit and just wanted to know before I would jump on a good deal....
97BlackAckCL Jun 27, 2009 12:37 PM
Just one thing to add guys, quote the person who you're responding to or answering
Gnate Jun 27, 2009 01:40 PM
I heard they are bouncy as f*ck. Well, their coilovers anyway.
Gnate Jun 27, 2009 01:46 PM
Originally Posted by 97BlackAckCL (Post 11032077)
:agree: Best suspension mod that I did, and I recommend it to everyone on here:thumbsup:
^ Grabbed that from that guys thread about having $500 to spend on his Cl, you were talking about energy suspension bushings...
Do yours still squeak like CRAZY? Or do you think I just need to lube them up more? Because it sounds really bad when I go over bumps.
97BlackAckCL Jun 27, 2009 07:05 PM
My PU bushings never squeaked, and my car has sat for a couple years since putting them on there, I would say lube them more
Dicorp Jun 28, 2009 12:46 AM
avoid Skunk2 springs. very bouncy and uncomfortable ride.
Gnate Jun 28, 2009 09:19 AM
What's the best kind? I tried astroglide and it just came right off after a few days
DaInFaMMuS1 Jun 28, 2009 12:02 PM
My bushing kit came with a tub of lube to put on the bushings, i would think yours did too cuz that would be the best. If not id use bearing grease, that would probably work well
97BlackAckCL Jun 28, 2009 01:32 PM
http://www.energysuspensionparts.com...shing-Lube.asp
http://www.amazon.com/Energy-Suspens.../dp/B000CN7B4I
1slo23 Jun 28, 2009 02:10 PM
Thanks. I'll just save more for the KSports or D2's.
South Jersey CL Jun 28, 2009 08:10 PM
I found these HIDs online for 36.99 http://www.vvme.com/product/detail-20023.html
since theyre so inexpensive do you think i'll have many problems with them? or should i just get a more expensive set?
97BlackAckCL Jun 28, 2009 09:59 PM
I def like my d2's so far, still need to adjust the shocks but I dig em
meh, you get what you pay for, I think you'd be better off with the guy in the gb thread for $60 at least he has a warranty
© 2026 MH Sub I, LLC dba Internet Brands
