prokit vs sportlines w/ 18's on 3.0 (PICS!)
Old 07-16-2003, 02:21 PM
teh Senior Instigator
CLpower's Avatar
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
finally uploaded these pics again for you guys!
pro-kit w/ 18's and tokico blues
sportlines
Old 07-16-2003, 02:25 PM
OrIgiNal GanGstA
ge1stn's Avatar
looks clean i like the black on black better just because it is diff
Old 07-16-2003, 02:27 PM
klepto's Avatar
Damn that shit sits low
Old 07-16-2003, 02:32 PM
CLpower's Avatar
it's actually lower now after it settled. Also, I use to be even lower when I had coilovers
Old 07-16-2003, 02:45 PM
DamnThisHobby'sExpensive!
Acura3.0CL's Avatar
im thinkin about sportlines...can u use KYB AGX's or is it too low of a drop for theose shocks??
Old 07-16-2003, 03:09 PM
CLpower's Avatar
it'll be as low as my car. Trust me it's pretty low. If you aren't use to driving a really low car i'd stay away from the sportlines. They also rub a little bit under hard driving w/ 18's and you'll need a serious camber kit.
Old 07-16-2003, 03:10 PM
CLpower's Avatar
here is another pic to get an idea how low it is
Old 07-16-2003, 03:39 PM
ENGAGE MY VTEC BABY!!!!!!
97Acura3.0CL's Avatar
hey do you have a problem with 18's and the sportlines? i am planning on getting 18's and a sportline, but do you ever rub? whats your offset?and are tehy 18x7.5 or 8?
which one ride better?
does anyone have pictures with the difference between these springs like ghander has posted but with different shocks to see if the car sits differently
Old 07-16-2003, 04:40 PM
CLpower's Avatar
read the above posts
Old 07-16-2003, 05:53 PM
r3mix3r's Avatar
ghander i have the same setup as you...do yours squeak when u go over a bump...
Old 07-16-2003, 09:40 PM
Atl/Mia reppin'
ATLcl98's Avatar
might be your camber kit squeaking?
Old 07-16-2003, 10:07 PM
A-CL CrAckHeAD
-=DjPharmacy=-'s Avatar
Sportlines with Koni adjustables and 18's + cheap ass camber kit (squeeky squeek) same setup but with Ingalls camber kit's all around - NO SQUEEKY!!!
Old 07-16-2003, 10:39 PM
DOOKS of hazard!!!!
d5c5b's Avatar
ive got agx's and nuespeeds....my front sits right at wheel well and back tucks just barely...prolly if i didnt have those subs back there the back wouldnt tuck! about an extra 150 lbs back there!
Old 07-16-2003, 10:42 PM
Still trolling
suXor's Avatar
When I had springs, my camber kit squeaked on bumps.
Old 07-16-2003, 11:00 PM
acura-cl.com OG
ding069's Avatar
Chris, you don't need a cmaber kit with bags? Or are you talking that you only ride at a height in specs?
Old 07-16-2003, 11:02 PM
r3mix3r's Avatar
It must be the camber kit What can i do to stop the squeaking really pisses me off sometimes feel like my shit falling apart... cause i cant change my camber kit now all these camber kits are soo freaking shitty...
and ghander is that ur car w/ the prokit and other rims or different car?
Old 07-16-2003, 11:51 PM
Delusions's Avatar
ghander, for the prokit do u need a camber kit?
Old 07-17-2003, 11:01 AM
CLpower's Avatar
rodxx, yea that's my car w/ my old rims. Also, my car makes a pop and sounds like something is about to break, i've gone through everything, even had friends go through and had the dealer go through it but no one can figure it out. It sounds like the car is just gonna break!
Delusions, I personally did not need a camber kit, but others have.
Old 07-17-2003, 12:04 PM
An online pimp
Casual's Avatar
Thats pretty clean yo. I se your in HB. You roll through Main street??
Old 07-17-2003, 12:35 PM
CLpower's Avatar
Yea, I live down there, I live on the corner of brookhurst and hamilton. Where are you at? What does your car look like? Say hi sometime
Old 07-17-2003, 06:22 PM
An online pimp
Casual's Avatar
Im in Irvine, well, ive only had my ride for about two weeks . getting suspension technique 2" drop on Sat. heh. I go to a few bars over there from time to time. So ill probobly see you around.
Old 07-17-2003, 06:46 PM
CLpower's Avatar
say what's up whenever
Old 07-21-2003, 11:47 PM
Still trolling
suXor's Avatar
I really should, but I don't. I get mad inner tire wear since I ride so low sometimes. In all actuallity, you can lift it up to have no camber problems, but that's no fun. You get air to ride low without bouncing all over creation. So since I ride tucked to the rim, no camber kit in the world will help.
Depending on how long my tires last, I may go back to stock height or jsut springs. I kind of miss a soft ride and being able to drive wherever I want.
Who knows....
Old 07-22-2003, 06:54 PM
ex3lerate's Avatar
i have koni yellows and the prokit and im absolutely loving it.. you have the options of lowering your car to different perch levels and adjust the stiffness by the turn of a knob.. personally the best combo available... in my opinion
MrHeeltoe
20
02-23-2023 01:54 PM
08KBP_VA
10-22-2019 01:55 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: prokit vs sportlines w/ 18's on 3.0 (PICS!)
