Power Seat problems
Power Seat problems
I'm having some difficulty with the driver power seat. It moves back fluently, but when I try to move it up it only moves and inch @ a time. N e 1 else have this problem? I saturated the bloody thing with WD40 and nothing.... Ideas?????
The inching forward is a very common problem with the '97s. There are a couple TSBs about it. A buddy of mine had it happen with his seat, took it to the dealer and they fixed it for him.
Here are some of the TSBs dealing with the power aspects of the seat. There are a couple more about the rear seat access lever not working properly.
Make: ACURA Model: CL Year: 1997
Service Bulletin Number: 96026 Bulletin Sequence Number: 17 Date of Bulletin: 06/96
NHTSA Item Number: SB048917
Component: INTERIOR SYSTEMS:TRACKS AND ANCHORS:FRONT SEAT: POWER ADJUSTING
Summary:
FRONT PASSENGER'S SEAT DOES NOT SLIDE FORWARD FOR REAR SEAT ACCESS.
Service Bulletin Number: 96019 Bulletin Sequence Number: 18 Date of Bulletin: 06/96
NHTSA Item Number: SB048918
Summary:
DRIVER'S 6 WAY POWER SEAT DOES NOT MOVE FORWARD OR BACKWARD
Service Bulletin Number: MSG96091 Bulletin Sequence Number: 35 Date of Bulletin: 09/96
NHTSA Item Number: SB049509
Summary:
UPDATE TO SB 96-019/POWER SEAT WILL NOT MOVE FORWARD OR BACKWARD. APPLY SILICONE GREASE TO THE NEW SEAT TRACK SYNCHRONIZER CABLE BEFORE YOU INSTALL IT. *TT
Summary:
Summary:
Summary:
I have a similar problem. At least I think it's a problem but maybe it's my ignorance. When you pull up the lever on the driver's seat should the seat power forward or stay where it's at? I was under the impression that it was supposed to move forward. It's harder to get my ho's in there when it doesn't move forward.
:P
billmcd
ILX
Oct 17, 2016 03:33 PM
rockyboy
Jan 25, 2016 06:00 PM
