okay.. now im confused
'07 November = STI
whats the difference between.. cold air intake and cold air shortram intake?
it looks totally different too.. haha
check it out http://cgi.ebay.com/ws/eBayISAPI.dll...969896962&rd=1
u guyz tell me .. whats the performance gain between a fat tube like this one and a standard 3" diameter shortram?
the cold air intake will go lower normaly in the fender or in that area to pull colder air. Colder air=more power......short ram will pull from the top of the motor which is normaly more hott. THe cold air will pull outside air in while the short will pull inside the engine bay air. Cold air=better-=more power.
eh f**k altezzas.
Originally Posted by Shaggz2Dope
performance is in the bends....
some people say SR is better and some say CA is better. but if you had a SR that had a sealed cold air feed, you might have something. some SRIs have an optional ram air conversion. its basically a box or cylinder that fits over your element and then has a pipe going into your bumper grill with a medium-sized collection funnel at the end. or you could just get one of those cryo2 intake chargers and have it installed around your intake pipe. somehow it uses liquid CO2 to drastically lower the temp of the air inside your intake tube therefore boosting power.(to about 4*F compared to about 90-100* inside the engine bay.) if you had both you could probably expect some pretty decent power gains on both end of the powerband.
eh f**k altezzas.
Originally Posted by VB87
and he's saying cold air short ram, like both of them combining together. Almost sounds like a V2
Originally Posted by BlueCLRycR
not always but yes if it has a bad design in the bends it will perform badly. all intakes are pretty much the same in the bends bc they all have to go TO the same place FROM the same place. also filter elements are CRUCIAL. shitty element=shitty performance.
i saw a write up on a mustang...( back when i had one) and a guy actually did a temp difference. at idle it was only a 20 deg difference, then after he hit 5 mph it was only a .5 degree difference. the cold air only benifits mostly from the stop. however the sri benifits in top end, since its more of a ram air. and the cai almost looses air cause of the speed going acrost the fender. like sucking the water out of a water bed using the water attatchment.
eh f**k altezzas.
Saucin
http://www.arospeed.com/default.php?cPath=22_37_39 thats what im talking bout
Saucin
NAWWWWSSSSSS
1 Post
god that would suck to have one of those.. you'd have to cover everytime it started raining.... also it would cost 100 to replace the filter you know how fast that would get dirty damn fast
'07 November = STI
Originally Posted by bkmc24
like the neuspeed one i think it is that looks like an intercooler kind of
legendary hows that electric s/c commin
so.. i decided.. im not gonna do it .. for now.. untill i decide to buy the fan off line.. hehe
sorry to keep your hopes up bkmc!
'07 November = STI
Originally Posted by thirdrail-1
think these are good? I thought about getting one....but said nah.
it should be fine, as long as you're okay with shortram.. it might actually sound more wistly.. depending..
i say go for it! its not that much $$ and u could experiment for us
Greengecko
09-16-2015 08:19 PM
