oil change question
oil change question
So ive had my car for a couple months now and since i got it i been putting in synthetic blend oil. Every 3,000 miles or 3 months. But this past oil change I went to a different place and the guy was explaining to me how "synthetic blend oil" is just a gimmick to make more money, like you think your getting a somewhat synthetic oil but it really doesnt make a difference and they're just charging you more for it. So he's like we use good oil here anywayz. So we dont carry synthetic blend only synthetic and non-synthetic. The synthetic was like 55.00 and I'm kinda cheeep so I went with the regular oil for like 20.00. My question is if you change the oil your putting in your from synthetic blend to just normal oil is that bad?? And can i still just keep using normal oil for every 3k miles? i have 60k miles on my car. Is the regular oil fine now or next time go back to synthetic blend? thankz
Gimmie my points Biatch!
Re: oil change question
But you will get longer life from synthetic and blends. If you still want to change ur oil at 3000, it might not make a difference if you are using synethic or not. The filter filters out the nasty chunks from the oil, the reason Y you have to change it is because the oil starts to break down from the heat and some stuff passes thru the oil filter that it can't catch.
Oh there is kinda of a myth that if u switch from reg oil to synthetic oil that your engine seals might leak on an older engine. I found out that only happens because u might already have a leak and oil that leaked out from the reg oil hardens and blocks the leak. Then when u switch to syn type it might knock the crude out and start leaking.
www.amsoil.com, they make really good synthetic oil and claim you can use it for 6 months at a time with their dual filter system. I know a couple of the guys here uses amsoil and swears by it. I on the another hand is too cheap to do it, lol.
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
