O2 simulator
O2 simulator
02 simulators does anyone on here use one if so where did you get it and how long have you had it. I already searched and none of the infomation i came up with was specific enough.Any help is appreciated
Originally Posted by AznX TL
ghost has one, why do you need it? going catless?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
You can just bypass it to the other sensor
And qsgreencl, which O2 sensor are you talking about? The one at the cat or the one at the header? I have my cat out and I bought an O2 simulator but it doesn't do shit. I also found this dudes website where he built one himself. I haven't tried that yet but if anyone else has a way of getting rid of the CEL then please help. Otherwise I will try this guys method. Here is the link.
http://home.insightbb.com/~niedejb/install2.html
666 Speed
1 Post
I have one... Had it for about 6 months now. Works great. Got it from www.02sim.com but found them on ebay...
http://cgi.ebay.com/ebaymotors/o2-Ox...QQcmdZViewItem
You should have found my thread on this a while ago...
I used the enclosed link to fix my toyota celica P0420. It works like a charm. Before the fix, the rear O2 sensor mirrored the forward O2 sensor voltage pattern which causes the ECU to set P0420. Afterwards, a nice smooth voltage trace and no P0420 for over a year now. I actually bought a replacement universal converter, but have not got around to having it installed since it requires welding to existing exhaust pipe.
Mechanical Fix for P0420
Regards
Regards
We ride RIMS!!!
i bought the same thing as the mechanical fix shows. I got it off ebay for like $15 shiiped. Will be tryin it tomorrow will let you know how it works! i am going test pipe for the future!!
I'll try one of these. Thanks. I bought another one off some other non-ebay website and it cost me like $80 CAN. And it doesn't work at all. And of course, they discontinued their O2 simulators and all service on them right after I ordered it.
We ride RIMS!!!
well i installed my test pipe and header today. Used the part i bought and no cel. Had to go to the local auto store (advance) and looked at the ones mentioned above. I dont think they will work b/c it is not deep enough for the o2 sensor to sit in. But the one i got has a 2nd part to it and makes it deep enough. Anyways its all done and sounds nice. No cel and i am happy. Now on to the next step!!
where is....
Regards
Regards
http://www.k-series.com/forum/showthread.php?t=8833
We ride RIMS!!!
heres a link to what i put on.
http://cgi.ebay.com/ebaymotors/S2000...QQcmdZViewItem
so far so good its been 3 days with no cel. I am running OBX SS header to a test pipe i got off ebay (had to weld in a o2 sensor bung) to a skunk 2 cat back. I love the set up. Has a nice deep tone.
666 Speed
1 Post
Originally Posted by qsgreencl
Was installing it hard or didi you have a mechanic do it.
I put it in myself when i replaced my o2 sensors. When they went bad, I soldered my O2 sim into the wiring. Its 3 wires. 2 splice into the signal wire and the other wires into the ground.
