Is this normal?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Sounds like your throttle position sensor (TPS)
(Mid-Atlantic)
(Mid-Atlantic)
Do you feel any slippage in the tranny? shouldn't be a tranny issue, usually unnatural reving is caused by the TPS but just wanna be sure
Fast Foward>Rewind>Play
does it rev up and down? like over and over? if so its the tps.
if its like a normal automatic transmission and depending how fast you stop from a higher speed. itll rev up a little than down to down shift.
(Mid-Atlantic)
(Mid-Atlantic)
def sounds like the tps
(Mid-Atlantic)
(Mid-Atlantic)
OK, what about loose throttle cable?
I still blame the TPS for being on it's way out, they're notorious for going bad on our cars.
where is....
it could still be the tps, but i think it would effect him alot more, im leaning torwards orlando3.0 because auto tranny waits til 2nd gear gets really low in rpm before it shifts down into first.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
