NEX Suspension
Old Oct 1, 2004 | 04:19 PM
Acura2.3CL's Avatar
NEX Suspension
I think that I have changed my mind and instead of going with tein, I think I am going to go with NEX SS Coilovers. I have heard that the spring rates on these are a little stiffer than teins and I think that might help keep it from bottoming out so much. Also, they have inner bump stops and that also sounds like a big plus so that I wont have to worry about cutting the bump stops or anything like that. And they are also only 600 compared to the 700 of the teins. And they are still adjustable to. What do you all think?
Can anyone who has/had NEX tell me how they like them?
http://store.rms-usa.com/nexfucosuki.html
^they seem to have the best price I have been able to find on these coilovers ($599).
Old Oct 1, 2004 | 04:44 PM
Acura2.3CL's Avatar
Oh yeah! I forgot...is it just me or in that picture does it only have 2 of the upper mount bolts. Do you all think that they are just showing an example and they will send me one with 3 like my car has, or is that a problem? Thanks!!
Old Oct 1, 2004 | 05:18 PM
creationCL's Avatar
CLanty-eyed
that looks like an example since they're using the same pic for all manufacturers. they look pretty good, tell us when you get em!
Old Oct 2, 2004 | 08:23 AM
Acura2.3CL's Avatar
yeah, i will be sure to keep you all updated, but it wont be for a little while since i have to save up to get the camber kits with them. Anyone else want to give me their opinion of them?
Old Oct 3, 2004 | 04:06 PM
Acura2.3CL's Avatar
bump
Old Oct 3, 2004 | 04:54 PM
ju5tchi11in's Avatar
roomate has a CL too
ive heard of them from d98clturbo. he was researching them and wanted to go with them but then decided to go with tein SS and the EDFC.
i would stick with Tein but then its ur money.
Old Oct 4, 2004 | 01:45 AM
lnsyone's Avatar
CL 4 LYFE
wow, they finally came out with the tein ss-p
Old Oct 4, 2004 | 10:09 AM
DigiBox's Avatar
Lots of JDM parts on my
A buddy of mine had them on his CL-type-S. They were SUPER stiff. Swapped them out for Teins. I guess if you can put up with the ride, then it will be okay.
Old Oct 4, 2004 | 01:30 PM
Acura2.3CL's Avatar
Thanks a lot guys!! One more question though. I have heard that the Teins bottom out quite a bit. Is this really bad for the coilovers, or is it basically just not a comfortable ride when they bottom out?? If I were going over an average size speed bump at a very low speed (5mph), will the Teins bottom out? Im just trying to get an idea about how much of an issue this bottoming out is. Also, do Teins have built in bump stops like the NEX do?Thanks again guys!!
Old Oct 4, 2004 | 05:57 PM
just depends on how low you are dropped. if you are only dropped 2 inches u aren't going to bottom out with TEINs. or anything basically... with a drop of 3.5 inches well u rub a lot... bottoming out in terms of scrapping the downpipe or muffler or something like that no... but tires hitting the fender liners yes.
TEIN is expensive for a reason. highly sought after and very good quality. if you don't plan on dropping it over 3 inches then go with the TEIN if you never want to rub at all... and if you plan on going lower then get the NEX and then you will never probably rub either. I have no experience with NEX but i got the SS on my car and i like them a lot.
Old Oct 4, 2004 | 07:38 PM
Acura2.3CL's Avatar
Alright thanks!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
