New tires...Need Alignment?
quick question peeps! I just got my tires rotated and new tires in the front... for some reason my steering is off by about 2 degrees. I'm assuming an alignmet. But i didnt expect to need one. Is this normal?
A-CL Totaled Member
Its recommended about once a year. The difference in tires may make it seem more necessary, so it may be a good time to do it. Personally i have no money so I would ignore it.
Its just a car.
I have that same problem too. When I got new tires, I also got an alignment but my steering wheel is still a little off. Guy that did my alignment said its ok. But the steering wheel not being centered bothers me. can it be anything else other than alignment?
Gimmie my points Biatch!
It can be: One tire is not inflated correctly, one is off by couple of psi, different tires on the car, shocks are bad or not worn evenly, Steering wheel is not aligned correctly. There are many others.
FYI: prior to alignment car did not pull in any direction. Even from a red light, my car would continue in a straight line.
After getting the new tires in the front: My car's steering wheel is off by 2 degrees, AND the car pulls to the Right!
You'd think the guys at Pep Boys [Local Car store] would have recommended an alignment.
emailnatec
29
09-28-2018 04:27 PM
Zonian22
11-14-2015 01:20 PM
