New plugs and wires
New plugs and wires
i did some searching and i am just confused
I am looking to change my plugs and wires and i am thinking about getting the NGK IX Iradium plugs and don't know which wires to get(i was thinking to get the NGK ones). First question is that, how hard are they to install, cause i don't know what the deal is with the gap? and how hard are wires to install?
last question is that what is the coil and do i need to change it to use iradium plugs?
thanks
thanks
Changing plugs is reallly simple. Take it out by loosening it just like a bolt, then put the new ones in. You don't have to do anything with the gaps.
Changing wires is even easier. Each wire has a number, match the new with the old ones. Take out the wires just like unplugging a plug from a wall.
nippon_wa 2.0
Originally Posted by SilverCL97
plugs and wires are too easy to change...
Flap.
Originally Posted by nippon_wa
how do u take the plugs out..? i bought plugs and wires.. but i just installed the wires only since i don't know how to take the plugs out.. (sorry i'm noob)
socket wrench
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by oct
the spark plugs are 16mm and i tighten mine to 17lbs
SSM Accord V6 6 Spd
If you look in the manual, it will tell you how many turns you need to turn the spark plugs. On our cars, the spark plugs are SUPER EASY to do. Some of the bigger v6s and v8s are hell to do spark plugs on. Wires are even easier.
not all wires have numbers on them... just do one at a time.. take one old one off get the new one thats the closest to length and put it where you just took the old one off from.
every basic tool set comes with a spark plug socket. as far as a torque wrench.. just get one of those cheap needle type. thier ony like 10$ and they are fairly acurate. the best is the break away, but thier alot more expensive. and for spark plugs and external engine stuff, the cheap-o will do fine.
How do you tighten them, do you need a torque wrench? Also, How do you loosen them/get them out, do you unscrew them with a wrench as well? Just need clarification
how handsome I am
i dont think you need a torque wrench, i just think they're neat. just use a deep 16mm socket and loosen them. after you loosen them all, you turn the car upside down and shake it.
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
xsilverhawkx
09-28-2015 06:51 PM
