need some opinoins.
need some opinoins.
I have a 1999 acura 3.0 cl. my transmission is starting to act up. when i put it in drive or reverse it starts to get in gear real hard and it makes loud clicking noise. my car has 122,000 miles but the motor runs real strong. never had any problems with it. how much does it cost normally and is it worth it or does the ride of car totally change. and what warranty does it usually come with? any suggestions would be great. thanks
Expect to pay 2500-3000 for a rebuilt transmission. Is it worth it? It depends on how much your car is worth to you.
Warranty will depend on where you get it done. A good shop should give some type of warranty.
does the ttansmission usual shift like new after u rebuild it? the car doesnt even shift hard. i brought it to a local tranny shop cause of the noise and he found a loose bolt on my axle that i replaced a month ago and he said it was all set. thats where the noise was coming from, and then it did it again the next day but not as loud. weird
at work i can get a rebuilt one for i tihnk it was $1400 after my discount
looked it up the other day. there are like 3 different ones to choose from all about 2-3 hundered bucks apart from each other.
