Need help with this
Need help with this
I bought the OEM keyless entry remote and I tried reprogramming it to my car yesterday. it disabled my starter and can't my car on. I was told to do it manually, which i did it. It worked yesterday then today i the same problem had happened. now i tried doing the same thing and it didn't work. I tried resetting my ECU and disconnecting my battery and that didn't work so im out of ideas now.
Originally Posted by agranado
yikes. I know some members on here have reprogrammed it to their cars... and also, that there are instructions on how to do it here somewhere too...
how handsome I am
Originally Posted by asianspec
Yea I followed the directions given on the forum. it doesn't make sense why it not working
send PM's to the guys/gals who've done it already. im sure they'll respond here or to you directly if they're still active...
Well I called the Acura dealership over here so they are going to help me out, but good lookin out!
Originally Posted by NitiNiteZ
u did the "on, off, press the button," repeating it like 10 times right? It worked fine for me... no starting problems. sO i dn't know what is up?
Originally Posted by h2o-pr00f
battery and all that are fine? maybe its not the remote that shut it down, how could it do that.. maybe its a coincidence?
Originally Posted by SupraManAG
posibility
maybe your security module is bad
maybe its fucking up your starter
its a possibility
its a possibility
One custom CL
no no
the security computer
i believe its located under the drivers seat
make sure you purchased the right remote and rule out that its not defective
try to find another remote and program it
no no
One custom CL
confirm the location of the security module
unplug it for 5 mins then replug it
also reset your battery one more time
first see if your car starts
if yes then try reprograming the remote
goodluck
goodluck
goodluck
goodluck
goodluck
goodluck
i like acura
under ur hood, the fuse box, check the one that says security or somethin to that degree. i was messin with somethin, poped that fuse, and my car wouldnt start but it would click, im pretty sure thats it. the same thing happend to me
yeah same thing happened to me...all youd hear in the car was tick tick tick tick and the car wouldnt turn on. I unplugged the security box under the pass seat and shut all the doors and it turned off. then plugged security box back in. started right up like normal.
there you go
wish I was home to look at my electrical troubleshooting book
Its ok meng! thanks for helping out tho!
Yea I tried that already. the fuse still looks good and i even pulled it out for about a min to see if ill reset.
I looked at it and i was wondering where on the security box did you pull it. all i saw was a bunch of wires and i didn't want to fuck it up even more.
Ok I tried everything and its still not working
haha i went to the car to i guess to pray that it will start and it started! i dunno how or why but it started. I thought that i was psyching my self so i did it again and it worked again. haha thanks for the help guys!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
none of the fuses were poped? even under the steering colum?
