My gas pedal and brake pedal are loose.
I'm a llama :(
When I step on the gas there's a little play, so it makes a noise. It jiggles side to side. I tried to find a way to tighten it, but I can't find it.
My brake dose the same thing. The pedal also bounces a little if I let go too fast.
ENGAGE MY VTEC BABY!!!!!!
you can tighen the throttle cable from under the hood, the brake peddle you can make it not so loose by purchasing some nice lins, like SS lines and also see if there is air in the line, try bleedign the lines by the wheels and see if there is some air in it, you will have to replace some brake fluid bu it should fix the problem
I'm a llama :(
SidhuSaaB
05-30-2020 12:40 AM
spoiler900
10-10-2015 06:48 PM
