Milling the head
100% Dominicano
Milling the head
What exactly does it mean to mill the head. What are the benefits? what are the disadvantages? How much does it cost? Is it worth doing to a 3.0 v6 CL?
Swaps? $3000 for 50HP? :(
Originally posted by djz
milling the head would be to remove material from the head.....basicly to increse compression (ie: more power).
You'll have to mill both of your heads.
CL's need steroids
I would do this last. Its a pricey Mod and depending on the new compression, you may have to get better pistons and especially rings. I believe unless your racing your car there is no need to do this for 5-7 extra hps max. This is also a mod that the more you have done to your motor the more beneficial it becomes.
milling the head increases compression ???
I always thought it refered to a port and pollish or extrude hone job. matching the intake runners to the block. To increase air flow to the clyinders. besides removing marerial from the a clyinder would decrease the compresion i thought.
Originally posted by Chen
heads have nothing to do with the compression. deck height, bore size, piston type, and rod length can affect the compression ratio, not a port and polish.
Milling the head is equivelant to lowering the deck height.
Porting and polishing a head is not the same as milling the face that sits on the block.
Eggs999bacon
09-24-2015 10:08 AM
