maybe some one can help me
I hhave a keenwood head unit in my car it's the 919 model but i installed it and i just keep getting an anoying noise every time i press te gas i hope some can help thanks
Try and check all your connections and make sure you have a good GROUND. Sounds like you have a bad ground loop. I think all of us stereo install junkies have been down this road one time or another.....
Work safe avatar bish :D
Unplug the rca cables going into your amp. If it stops doing it then you can get this thing you hook up in between your cable and amp that takes out the noise. If not, then they sell this little transformer that you can put between your ground and power cable that will give you a better ground and take out the noise.
