Lights..
Old 02-27-2002 | 04:44 PM
KingsFanPaul1's Avatar
2002 NBA Champs!!!
Lights..
hey I just got my PIAA 9006 Superwhites in the mail anything i need to know before I try the install? any helpful hints?
Old 02-27-2002 | 04:57 PM
Nugs3's Avatar
don't touch the lens.....plug and play!
Old 02-27-2002 | 04:59 PM
2002 NBA Champs!!!
do i have to re adjust the headlight levels or will they be ok? if so is that difficult to get them straight?
Old 02-27-2002 | 05:16 PM
Nugs3's Avatar
I've gone through 3 sets of lights and never had to re adjust the lights..............put them in and pull up to your garage door to see where it aims. I'm pretty sure you'll be alright. remember don't touch the lens or even let parts of your car touch it..........guide it in nice and slow.........pretend your playing the operation game.
Old 02-27-2002 | 05:19 PM
2002 NBA Champs!!!
DAMN! i sucked at that game.... j/k
Old 02-27-2002 | 05:35 PM
SumkidwithaCL's Avatar
Turn Signals are good!
Yeah i was pretty bad at that game too!!
When removing the bulbs, you gotta unplug the harness first... theres a little "button" to push then they slide down off the bulb... then the bulb just turns out of its holder. They will not come out unless the harness is unplugged.
Old 02-27-2002 | 05:40 PM
Nugs3's Avatar
I forgot about that step......also when you put them back on the grooves/tabs must line up.....it will more than likely require you to start with the bulb turned instead straight in with connection part at the bottom. did this make sense?
Old 02-27-2002 | 10:39 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
I've been through several sets of "HIDs", and only needed to reallign my beam pattern this past time. All turned out well! Good Luck!
PS: DO NOT TOUCH THE GLASS BULBS!!!!!
OK; continue with your day!
AcuraFrauds11
18
09-21-2011 11:34 AM
ecliptics
3G TL Photograph Gallery
21
07-19-2007 05:18 AM
ResidualFreedom
12-28-2005 09:38 PM
nippon_wa
02-06-2004 10:26 PM
ComptechType-S
03-13-2002 12:55 AM
