K24?
I
K24?
I remember reading in like... last last months hondatuning about the new hasport kit for K24s in CD Accords...
so whos gonna be the first to put it in a CL? Anyone even thinking about this?
would it be possible to have a k24 block with a k20 head? has anyone done that yet? that would be pretty hot to have in a 1st gen. If theres kits for the k24 swap into an accord, it can go into a CL too right?
Ciao Pho Eva eva
Originally Posted by sixfifty
im pretty sure they're less than the K20s.
i dont think the swap would be worth the money. Although the swap would be unique...its somewhat rare and would cost alot of money and so-so performance results when ... for the same amount of money you could swap the classic H in there and with the extra ( K ) money...start modifing. Although this isnt anything new...which may be the whole point to the K swap....its more cost effictive and will give you better performance gains ....minus the 6th gear. Your looking at 6 to 7 thousand dollars for a proper K swap labor excluded. Think about that. Yes, it would be the First for the 1st gen Cl......but not the first for the platform. Its been done by hasport using the accord. Remember......performance comes first....being unique later for those who realisticaly cant afford these ( dream ) swaps. Ill post pictures of my F20b swap tommaro. Everything went well and after the test drive........WELL worth the money if your car has weight reduction done to it.
Ciao Pho Eva eva
well.....i didnt exactly ruin the F22......but i did destroy the head and ive had this F20b in my garage for over a year. Soooo, why not ? The f20b isnt exactly built, but the comp was raised after the decking and clearance was check ftw. I should see some great N/A no nitrous action for a bit....unitl i got pics ready...ill load em up. BTW, the owner of the car before me....lives 2 houses down here in CO ....no joke.
where is....
i've been hearing about the k24 block with k20 head making around 230whp.
what would be even better is if someone took the whole awd system out of the crv and the k24 block, and swap a k20 head on there. that be a great car, you'd have minimum tire spin from a launch, and have 230whp to your advantage. but i bet it'd make the CL weight as much as a crv though.........even though the weight is pretty close as it is
Senior Airman
The K24 is a good motor to build/tune!
I would def be interested in seeing that go down!
cycdaniel
12-17-2019 10:58 AM
oyayjoe
09-12-2015 04:40 PM
PixelHarmony
31
03-31-2006 07:00 PM
